1978 - 1996 Big Bronco
The Do-over
Old Apr 15, 2014 | 12:07 PM
Fordman96's Avatar
Fordman96
I think it's the proportioning valve that has to be changed, but I've been reading into either hydroboost or an f350 master cylinder/booster swap.
Old Apr 15, 2014 | 04:06 PM
GruesomeJeans's Avatar
GruesomeJeans
Yeah the prop valve. For some reason that name always escapes me. Any was for hydroboost you definitely need new stuff. I've been told I should look into an f350 setup for my 78. It might be worth it since I need to redo the entire brake system..
Old Apr 18, 2014 | 08:26 PM
Fordman96's Avatar
Fordman96
It's been a while, but I finally got my back axle home yesterday. Cleaning that up will begin tomorrow after work and after I get the headlight bezel back on.
As for tonight's progress, I got the headlight bezel off, minus the trim piece underneath that I couldn't get to yet. It took probably 2 hours to get off due to a 20-30 minute hood latch not releasing delay and cooking dinner.
I'll get some pics tomorrow since the last 45 minutes of the work was lit by a shop light.
Old Apr 20, 2014 | 07:48 PM
Fordman96's Avatar
Fordman96
Today was more of a cosmetic work day than a mechanical work day.
I got the brackets for the headlight bezel cleaned, primed and painted a metallic silver.
Along with both mounting brackets for my Dick's Cepek light bar.
Brackets all on and everything but the grill bolted down.
Then the grill got bolted on.
Along with the light bar which had to be cut down 2 3/8" to fit on the truck. She looks kind of funny without lights though. Anyone have any recommendations? Looking for 2 spot lights in the middle and just a spread light on the outsides.
After all that was buttoned up (still have to get the trim piece underneath sand blasted which is why it's missing.) I went sanded the sun visor then sprayed it with the same metallic paint.
As for mechanical things. I got the front axle torn down. Took some beating with a sledge hammer and some melting with the oxy/acetylene torch. Turns out it has 4.10s, BUT the pinion gear needs replaced since one tooth is shattered.
Old Apr 21, 2014 | 07:51 PM
Fordman96's Avatar
Fordman96
So today I started to tear down the rear axle I bought the other day. Found the axle ID tag, but it doesn't seem to match up how I found on a website.
Differential Identification | West Coast Differentials
Under ford differential tags.
My tag says:
SS124G
55 10 2 4G29
From what I can decode. It's a Sterling made July 29, 1994. Right?
Old Apr 26, 2014 | 09:41 PM
Fordman96's Avatar
Fordman96
Well finally got the rear axle all the way down. 3.55 gears.
Took both axles to the power wash and cleaned them inside and out, then took them to my sandblasting guy.
Considering getting EGR/tube, but not sure if I want to spend ~$200 on those if I'm going to swap to a diesel (time frame on that unknown.)
Currently researching disc brakes for the Sterling 10.25.
Other then that not much activity lately, been really slow.
Old Apr 29, 2014 | 05:30 PM
Fordman96's Avatar
Fordman96
Both axles are at the sandblaster. He's not in a big hurry to get it done, and neither am I since the weather is calling for rain all week I don't want to try and bring them home in the rain.
One of the 4x4 guys at the blasters place looked at the front axle and he thinks it's a D60 king pin, while another guy on here thought it was a D44 HD. (can't find any serial numbers to confirm yet.)
The rear axle will be converted to disc using Ford Sterling Disc Brake Bracket 84-94 - RuffStuff Specialties
As for slow progress this week, got the sun visor on.
It has the same metallic silver paint that the mounting brackets for the light bar has and it has given me another option for truck paint.
Old Apr 29, 2014 | 05:31 PM
Fordman96's Avatar
Fordman96
Progress may get slower if I get another truck (for work) which will put money expenses away from the bronco.
Old May 4, 2014 | 08:17 AM
Fordman96's Avatar
Fordman96
Yesterday was Broncorama! Didn't really sell much, but I got some nice compliments on the truck and of course the naysayers.
I picked up 2 very good looking door panels for $25 for the pair, 2 tow hooks (up to 6 now) and a brand new, never used, freshly painted, tailgate for $150.
Old May 4, 2014 | 10:20 AM
'86 F150's Avatar
'86 F150
Good finds. Was the tailgate the red one? I didn't sell anything I brought to sell, but my dad did alright.
Old May 4, 2014 | 03:33 PM
Fordman96's Avatar
Fordman96
Ya it was the red one behind the black/green 2 tone quad cab f350.
Old May 4, 2014 | 05:17 PM
Fordman96's Avatar
Fordman96
I haven't had a chance to do much since the weather doesn't like to cooperate. If it's warm it's windy, if it's cool its trying to rain.
I got my axles back was able to get sandable primer and filler primer on roughly 90% of it (couldn't turn it over before the wind picked up.)
Old May 4, 2014 | 05:22 PM
  #28
Fordman96's Avatar
Fordman96
The local show truck is up for sale. I figure I'd show it off. $45,000. Numerous awards, 47,000 original miles. Neon, chrome, undercoating. 454, coated headers, stainless steel exhaust, 70s ford 3/4 ton axles.. 15" chrome rims, forget the tire size.
The neon lights
I think I'm going to try and aim for this level of professionalism or better on mine.
Old May 5, 2014 | 12:13 AM
  #29
GruesomeJeans
The bronco in the background? Hehe, just kidding, that is a pretty nicely done GMC. Everything is clean and tidy.
Old May 11, 2014 | 06:59 PM
  #30
Fordman96's Avatar
Fordman96
So this weekend I worked on swapping out the tailgate I bought at Broncorama. $150, brand new, unused and painted not primed!
Unfortunately I was focused on the tailgate on only snapped photos when I remembered too.
First thing I did was strip down the tailgate.
Glass, motor, gear, handle, switches, wiring, and rails. Also the weather stripping came off. Unfortunately I need all new weather stripping so that didn't get put back on.
Tailgate is off and I got to work on some of the rust on the body.
Sanded it until I was somewhat happy with the work for now. Until I get a sand blaster later this summer.
Got it primed and threw a coat of left over paint on it.
(This is primed)
New tailgate (still in the new box)
Skip ahead after I have it 85% back on.
I noticed I had a few wires corroded off and broken that connect to the window (I assume it's the defroster wires.)
After I got some adjustments done and was happy with how it is until I get the new quarter panels.
Tomorrow I'll be buying a whole weather stripping kit from JBG.
The axles are covered in undercoating. Stupid me still doesn't know what my front axle is so I may just sell it and head to LKQ Pick Your Part - Grand Rapids | LKQ Pick Your Part and see what I can find to match my rear axle. I have some phone calls to make tomorrow before my decision is final.
