Oil standpipe spring.
Old Mar 29, 2014 | 01:19 PM
jayc3169's Avatar
jayc3169
I've had my truck since 2006, I've put well over 150,000 miles on it. Recently I've had some stiction issues so I decided to put some rev-x in it. I've watched ton of vids on youtube about adding it and oil changes. In each of the vidoes I've noticed they are talking about how when you pull the oil filter it should spring out a little. Mine has never done this. I'm using motorcraft oil filters and the oil cap appears to be OEM. Should I be worried, is there something I can check to see if its broken?
Old Mar 29, 2014 | 01:30 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's spring loaded as you push the cap w/ filter down.
Josh
Old Mar 29, 2014 | 01:31 PM
jayc3169's Avatar
jayc3169
Josh
No mine! It slides right down, no spring back!
Old Mar 29, 2014 | 01:32 PM
Bullitt390's Avatar
Bullitt390
Early 03 wasn't spring loaded.
Josh
Old Mar 29, 2014 | 01:34 PM
jayc3169's Avatar
jayc3169
Josh
*Wipes forehead* Thank you, I thought I had another problem on my hands.
Old Mar 29, 2014 | 04:35 PM
vloney's Avatar
vloney
Look inside your oil filter. At the top, inside, theres a hole. That "button" on the standpipe plugs it up. Its a Bypass if your filter gets plugged up. Another reason not to use aftermarket caps and filters.
Old Apr 4, 2014 | 02:08 PM
11jjonn's Avatar
11jjonn
Josh
Really happy to hear this.
I even sent photos of my early 2003 6.0 PSD (feb 30 ?) oil filter housing to my local Ford parts dept - they claimed that ALL 6.0's were spring loaded!!
I wondered why their service dept never mentioned the missing spring assy during the last 4 oil changes
Think I'll be doing the minor maint myself for awhile............
Tx so much for the info.
Old Apr 4, 2014 | 03:53 PM
KDAVID1's Avatar
KDAVID1
smart decision
Old Apr 5, 2014 | 12:12 AM
Bullitt390's Avatar
Bullitt390
Just for the sake of anyone observing this thread:
Old Style Stand pipe
Updated Late Style
Randy777
Apr 19, 2014 10:50 PM
flexman
Oct 10, 2010 11:11 PM
-=Pit=-
Feb 27, 2010 03:12 PM
96bigblueford
Mar 3, 2005 10:44 AM
Kwikkordead
21
Feb 25, 2005 10:51 PM
