Oil Filter
Old Feb 27, 2010 | 02:42 PM
-=Pit=-'s Avatar
-=Pit=-
Oil Filter
Guys,
I just did my oil change and maybe I am just getting old and "C" nile but when you loosen up the filter housing cap I swore there was a spring that popped the cap up once it was completely unscrewed. Am I correct or just loosing it? I called the dealership and they could not find one (thought I lost it) so know I am scratching my dome.
Spring
or
Nuts!
Pit
Old Feb 27, 2010 | 02:47 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
Old Feb 27, 2010 | 02:50 PM
cheezit's Avatar
cheezit
nope no spring. just a standpipe
Old Feb 27, 2010 | 02:51 PM
cheezit's Avatar
cheezit
were on earth do you guys keep getting all the pretty pictures man Im so jelous.
69cj's Avatar
69cj
That spring effect was the drain back valve in the filter housing. When you lift the filter a drain valve opens letting the oil in the filter housing drain into the oil pan. When you install a new filter and screw the cap down it closes the spring loaded valve. Lube the O ring with oil, snap the filter into the cap and screw down till the cap bottoms out. Then torque to spec.
Old Feb 27, 2010 | 02:53 PM
SteveBricks
FTE Emeritus
6.0 bible in the tech folder sticky:
6.0L Bible Table of Contents
Old Feb 27, 2010 | 03:06 PM
-=Pit=-'s Avatar
-=Pit=-
Thanks I was just making sure....
One last Q...the zerks on the front axles to grease the U-Joints...Normal Bearing/Ball joint grease is acceptable?
Time to hit them and I know I never have, the dealer for dam sure didn't.
Thanks,
Old Feb 27, 2010 | 03:12 PM
69cj's Avatar
69cj
Thanks,
That's good. I like the hi-temp grease for the wheel bearings.
