Sponsored by: Real Truck
Mystery Switch
Old Mar 28, 2014 | 09:11 PM
robwhite61's Avatar
robwhite61
Mystery Switch
My 2001 F350 XLT DRW with the 7.3 has a small toggle switch in the fuse panel almost directly under the steering wheel. It is high enough so you can't accidently trip it with you knee, but is accessible by reaching under the panel. It's a two position switch. Does anyone on here have any idea what it is for. I'm stumped.
Old Mar 28, 2014 | 09:33 PM
Bigpipes 35's Avatar
Bigpipes 35
Sounds like a valet switch for a aftermarket alarm system..
Old Mar 29, 2014 | 04:24 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
There is absolutely no way for us to know. It could be literally anything. We could guess, but thats about it. Trace the wires....
Old Mar 29, 2014 | 04:30 AM
r___r's Avatar
r___r
+1 on valet and tracing the wires out.
Or a no start switch.
Have you tried it to see what happens.
Good Luck,
Old Mar 29, 2014 | 07:00 AM
rjcorazza's Avatar
rjcorazza
Who knows, but if the previous owner did a little reading it may be a fast idle mod. Try setting the parking brake with the engine over 60 deg for a diesel (140 for gas) and flip it.
Old Mar 29, 2014 | 07:36 AM
tjc transport's Avatar
tjc transport
i ain't rite
or it could also be snow plow lights.
Old Mar 29, 2014 | 07:40 AM
asdrew's Avatar
asdrew
If it was on any of my trucks through the years, it could be anything. A previous owner like me must have installed it and the only way to find out why is to trace the wires.
Things I've used hidden switches for in the past:
- fuel shut off tied to inertia switch
- brake shift interlock so I could leave engine running
- lighting & inverter relays
- delayed timer for alarm (in case someone stole my alarm key back in the day)
- accessory power
Old Mar 29, 2014 | 08:25 AM
robwhite61's Avatar
robwhite61
Well, the mystery switch doesn't affect starting, so I'm guessing some kind of alarm switch that must have disabled before I bought the truck.
Old Mar 29, 2014 | 08:45 AM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
The old Diablo chips had switches like that, maybe it doesn't work or the switch was just left in to cover the hole. Or maybe a stealth mode switch where no one can see you when it's on.
Old Mar 29, 2014 | 09:24 AM
00BlueOvalRanger's Avatar
00BlueOvalRanger
It could be anything, from auxiliary lights, to a timed self-destruct circuit, to sideview mirror heaters, to ___________________.
About the only way to REALLY find out what it's for, is to trace the wires from the back of the switch to the end of their run.
Skorpion007
Jun 15, 2020 10:01 AM
23larry24
Feb 3, 2013 05:08 PM
EPDP99
May 9, 2006 07:43 AM
RICHMC54
Dec 5, 2004 05:18 AM
hedstrawng
1997 - 2003 F150
Dec 11, 2003 12:32 AM
