Wont shut off!!
Old Mar 28, 2014 | 07:07 PM
ou8126521's Avatar
ou8126521
4wd High
Wont shut off!!
I have a 2004 F150 Lariat 5.4 new body. It has 165000 miles. It just did this today, turn the key off and it continues to run. I had to disconnect the battery and pull the plugs off of the computer to shut it off. when I re connect the battery all the dash lights are on the odometer everything like if I had the key in the on position. I checked the ignition switch it still does it even when I have the ignition switch wires unplugged. The lights only go out if I disconnect the wire from the battery that goes to the fuse box. Has anyone heard of this?
Sean11
2004 - 2008 F150
13
May 7, 2019 12:27 PM
Spotty
1997 - 2003 F150
Mar 24, 2013 10:12 PM
PrintNCut
15
Aug 2, 2009 06:50 PM
MBBCop
Electrical Systems/Wiring
13
Feb 17, 2007 01:57 PM
83_f-100
13
Oct 20, 2004 07:56 PM
