ignition is dead
Old Oct 20, 2004 | 05:03 PM
83_f-100's Avatar
83_f-100
ignition is dead
ok heres my problem. I have a 83 ford f-100 with the inline 6. I cannot get it to do anything by the ignition and I mean nothing its like there is not a battery in the truck (brand new battery). Now I can "jump" the solinoid switch with a screwdriver and it will fire up but as soon as I l pull the screwdriver off it dies like I turned the key off. help me please
Old Oct 20, 2004 | 05:31 PM
84-250's Avatar
84-250
when you turn the key and nothing happens but stater turns by jumping the solienod then replace ignition switch
Old Oct 20, 2004 | 05:33 PM
f100guy's Avatar
f100guy
i know this one, it is one or 2 of the fusable links. they are inline fuses that connect the the hot terminal of the solinoid. there should be an orange rubber bootlike thing on a couple of wires and they say "fusable links". what i do is strip a little bit of wire on each side of the fusable link and use a test light or some sort of electronic device to tell you that something is shorted or blown.
Old Oct 20, 2004 | 05:36 PM
83_f-100's Avatar
83_f-100
its not the ignition switch I tried that havent tried the fusible links anymore info on where to find these would be helpful also I have no lights or ding from the doors nothing at all.
Old Oct 20, 2004 | 05:49 PM
f100guy's Avatar
f100guy
that is definately the fusable links, my mustang did it. look on the positive post of the solinoid, you will see a couple of smaller wires there with big orange rubber things on them saying fusable link. i would just cut them out and replace them with a buss fuse. i can try to find a picture for you
Old Oct 20, 2004 | 06:06 PM
f100guy's Avatar
f100guy
they may look like these, where it looks as if shrinkwrap was used over a regular wire, it says fusible link in white letters. http://www.chaosboyz.nl/images/techn...e/ampere18.jpg but i think you have the other kind which i am still looking for a pic of.
Old Oct 20, 2004 | 06:28 PM
f100guy's Avatar
f100guy
what the hell happened to the search on this site.
Old Oct 20, 2004 | 06:40 PM
83_f-100's Avatar
83_f-100
I remember seeing one of those how many is there?
also do you have a diagram or can you explain which wires go where on the solaniod because I was not the one to hook it up and I want to be able to double check it.
Old Oct 20, 2004 | 07:14 PM
f100guy's Avatar
f100guy
ok i was just checking that for the past 35 minutes. there may be only 1 or 2 but the diagram i just looked at showed just one. let me get a website
Old Oct 20, 2004 | 07:17 PM
83_f-100's Avatar
83_f-100
would that fusible link stop everything from working including headlights and such?
Old Oct 20, 2004 | 07:23 PM
f100guy's Avatar
f100guy
yes it did it on my 89 mustang while driving, i even saw it glow red through my cowl hood.
Old Oct 20, 2004 | 07:28 PM
f100guy's Avatar
f100guy
http://www.autozone.com/servlet/UiBr...3d800ce982.jsp
go to fig.13 and click on it to view it. it is showing one but there may be more.
Old Oct 20, 2004 | 07:29 PM
f100guy's Avatar
f100guy
when you click on that site, you have to scroll down and click on CLICK HERE to get to the site.
Old Oct 20, 2004 | 07:56 PM
83_f-100's Avatar
83_f-100
houston we have a problem my solanoid only has 3 post not 4
I have:
red wire that goes to battery
no black and yellow as far as i can remember
I have black wire that goes to starter
and I think a red and green that has a small boot like end on it that just pushes onto the prong
I think thats all but I know its a 3 prong and I have 4 wires running to it. dont know if its the right one or not
