Sponsored by: Real Truck
Need help! - Brakes
Old Mar 28, 2014 | 05:40 PM
smlford's Avatar
smlford
Need help! - Brakes
A couple of times recently my brakes have been very hot when I stopped.
I took it to my mechanic who took it for a drive and then used an IR thermometer to measure the rotor temps.
The front right and rear left rotors were at least 40 degrees higher than their opposites on the same axle.
He believes it is probably the master cylinder..
Any thoughts?
Thanks!
Old Mar 28, 2014 | 06:37 PM
jswartz84's Avatar
jswartz84
A good flush and clean up the calipers.
If the master cylinder was bad, I would expect all corners to be hot or at least in front or rear pairs.
Old Mar 28, 2014 | 06:38 PM
69cj's Avatar
69cj
Since the high temps are not uniform I would be more inclined, with the info supplied, that you have calipers that may be sticking. You also need to do rotor run outs as part of the decision.
Old Mar 28, 2014 | 06:52 PM
Maxium4x4's Avatar
Maxium4x4
I moved you to SuperDuty for a better response
Old Mar 28, 2014 | 07:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Your slide pins are probably sticking. Its common. Ford has released revised slide pins. Pull the slide pins and grease them. Install new updated slide pins if you wish.
Old Mar 29, 2014 | 06:02 AM
smlford's Avatar
smlford
Thanks everyone!
I had the caliper pins worked on a few thousand miles ago but may have to revisit the issue.
If the master cylinder WAS bad, what would the symptoms be?
Old Mar 29, 2014 | 07:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
if the master cylinder was bad the symptoms would be fluid leaking, or no brakes, or all the brakes dragging.
40 degrees difference is not a big deal. 400 degree difference is a big deal.
Old Mar 29, 2014 | 08:29 AM
Tom's Avatar
Tom
Tom and I actually agree on something.
Agree that it's not the master cylinder. You can have stuck slide pins or stuck caliper pistons that can cause that. And both are relatively common, so that would be where to start.
Old Mar 29, 2014 | 09:14 AM
tjc transport
i ain't rite
lets not make a habit out of this!!!
jimalbert
Dec 11, 2014 10:57 PM
Fully_Loaded
19
Aug 12, 2004 12:38 PM
johnsonacres
Mar 15, 2004 07:31 AM
rockcrawl86
Dec 3, 2003 02:21 PM
msbhvn
Offroad & 4x4
Mar 8, 2000 11:48 PM
