Sponsored by: Kumho
master cylinder
Old Mar 14, 2004 | 06:54 AM
johnsonacres's Avatar
johnsonacres
master cylinder
I recently did a brake job on my 71' f-250 4x4. It has front and rear drum brakes. I replaced the master cylinder. It has a small and large reservoir. I have since read in this forum that for drum brakes the reservoirs should be the same size. Is this going to be a problem? I also noticed while bleeding the brakes that the small reservoir (closest to the front of the truck) fed the rear brakes is this right or do I have my lines crossed up? The back brakes seem to work fine, the front brakes don't seem to work as well. Thanks, for the help.
Old Mar 14, 2004 | 11:49 PM
FSC's Avatar
FSC
the reservoir is ok, it will work
the rear brakes are usually supplied from the rear, thats OK as well.
the only question I have is, are you sure you have the correct master cylinder? You very well may have but I would double check with the parts house to make sure.
It always raises a red flag with me if the new parts are not EXACTLY the same as the old. FSC
Old Mar 15, 2004 | 07:31 AM
johnsonacres
Thanks FSC for the reply. Next time I go to town I'll go back and talk to them about this master cyclinder. Again, thanks for the help.
