engine swap alternator differences
Old Mar 29, 2014 | 12:06 PM
1990-f250's Avatar
1990-f250
Originally Posted by ArdWrknTrk
Thanks Ian!
I see now the fusible links are outboard of the green 'tag' in question.
The wire you point to needs to be connected to the charge indicator.
If 1990-f250 has the correct end I'm sure he could just solder it on.
OK thanks, so I can just cut both connectors off and solder them? That would be the easiest for me
Old Mar 29, 2014 | 12:23 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I would probably cut one side of the connector off (truck -or- harness) side and solder on the mating connector.
Instead of soldering the wires to each other.
It will make things much easier if you ever have to remove that section of harness.
Old Mar 29, 2014 | 12:25 PM
1990-f250's Avatar
1990-f250
OK, that sounds like a better idea. I'll probably just match up the connectors that went with the old charging cable, that way i can be sure it will work
Old Mar 29, 2014 | 12:37 PM
Conanski's Avatar
Conanski
Do you have a lot of electrical accessory load on the truck? If not and you just weant to get it on the road just use the '90 alt and bracket for now and do a 3G upgrade later... when you know everything else works as it should.
Old Mar 29, 2014 | 12:42 PM
1990-f250's Avatar
1990-f250
Is there more to a 3g swap than just a new charging cable?
Old Mar 29, 2014 | 12:46 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Not really (in your case)
Walleye Hunter
Jun 1, 2016 06:17 AM
christaylor
Feb 21, 2015 07:02 PM
IDI-Charlie
Electrical Systems/Wiring
Apr 2, 2014 10:24 PM
chrismartinez0
May 22, 2010 05:37 AM
lpmorgan
Sep 25, 2005 07:47 PM
