300 build up
Old Jul 3, 2003 | 12:57 AM
osborn_1's Avatar
osborn_1
300 build up
i am currently looking for a 300 to build up to replace the one i have. i plan on electroni ignition, an efi exhaust manifold, offy intake with 4bbl carb and probobly a crane cam. is there any "better years" to look for for my new motor and wich years or moddles would have better heads?
Old Jul 3, 2003 | 03:32 AM
Ford_Six's Avatar
Ford_Six
300 build up
The lower end you have now will probably be fine. You want pistons for an 8.7:1 compression motor, Silvolite #1170. Use a head from a 240, and you will have compression in the range of 9.2:1. This is the easiest way to get good torque and power numbers, but still pass the sniffer test.
Old Jul 3, 2003 | 09:58 PM
paulfix's Avatar
paulfix
300 build up
If anyone out there has Desktop Dyno 2k or or similar, please can you plug the above compession ratio into the prog and post the results. Thanks much
