alpine Amp/factory deck question
Old Mar 28, 2014 | 03:27 AM
NobreaksNorton's Avatar
NobreaksNorton
OK so I bought a 2012 F150 Fx4 Crew cab. I dont have the lCd screen it is stock stereo, No i do not have the premium Sound system so no factory Sub..
My question I have Alpine Type S sub. 12 inch. an alpine amp Mono power amp MRP-m500
No i know i need some kit or something. I want to know the cleanest way to do this. guy at best buy said to go thru speaker wires but my speakers are in the doors an. I want best possible connections to do this correctly so i dont have a wire mess.
Can some one Show me a link to the parts needed for the hook up. so i can order them an a guide to do it all. im tired of finding things that briefly explain what to do. i just spent 40k not trying to rune my interior my 02 explorer was easy
Old Mar 28, 2014 | 02:37 PM
NobreaksNorton
can any one help me?
Old Mar 28, 2014 | 02:53 PM
NobreaksNorton
guess not?
Old Mar 28, 2014 | 03:42 PM
NobreaksNorton
Guess ill go elsware
Old Mar 28, 2014 | 04:06 PM
Robbgt's Avatar
Robbgt
Welcome to FTE.
Not everyone has a sub. I would give it some time, try the forum search or google if you need an answer right now.
Old Mar 29, 2014 | 12:24 AM
CuNmUdF250's Avatar
CuNmUdF250
omg dude relax....guys on here love to share their insight or lack of ...someone will be along to help....shouldn't be to hard to run a couple of wires, I`d run em under the carpet along the edge by the doors
Old Mar 29, 2014 | 07:21 PM
ososlow's Avatar
ososlow
Buy a Metra BT5520 harness to plug in between your factory head unit and harness.
Axxess BT5520 T-Harness Integrates Parrot Hands-free Bluetooth Kit
There are 4-5 wires that only go between the two black plugs. Rip them out and plug the black plugs into each other.
Since it looks like there are only 4 wires that go into your amps speaker level input. Run 2 lengths of speaker wire from the 5520 along the drivers side under the sill tray to the rear where your amp is mounted. On my screw I recall it taking pretty much all of the 15' lengths of wire I bought to make it from the harness to the amp which I mounted behind the drivers rear seat.
OR you could locate the speaker wires in the b-pillars and just splice in there. But I prefer not to screw with my factory wiring at all. Plus the b pillars are a pain to get out of the way.
To power your amp. Don't waste your money on an amp kit, you only need the fuse block, fuse and power wire for this. Buy a fuse block and the appropriate fuse for your amp (or use a circuit breaker). Mount the block as close to the battery as possible. I screwed mine to the plastic battery box. If you're mounting the amp on the drivers side rear like I did, you'll need ~20' (a little more couldn't hurt) of 4awg power wire. (any decent car audio shop will sell it by the foot) Run it through the rubber grommet on the passenger firewall. I used some heavy solder and felt around for it inside the cab. You'll really have to reach for it. Tape power wire to solder and pull through firewall. Run the power wire under the passenger side sill plate to the rear and along the back wall to your amp. Cut excess wire off and use that for your ground wire. I used the middle seat belt mount for my ground.
This should at least give an idea of the direction you need to go. There are a lot of little details that you'll need to figure out on your own. Like how exactly you want to run the wires and what you want to tuck them behind and secure them to.
Best of luck.
Old Mar 31, 2014 | 01:44 AM
vipervick's Avatar
vipervick
I bought a 2012 F-150 Supercrew Ecoboost in October 2012, and I still can't find any help on upgrading my factory stereo. The info must be buried with Jimmy Hoffa...
Old Apr 1, 2014 | 12:22 AM
ososlow's Avatar
ososlow
Here are the videos I used to help me with my install.
If you have a flow through console, the first few minutes of this one shows you how to move it back to remove hu front panel
HU removal
Door speakers
Having a laptop and wifi that reaches your driveway/garage helps a ton with reviewing these videos inside your truck.
I have never done an amplified stereo before. I have only done HU and speaker swaps. Reviewing these videos and a couple threads on one of the F150 boards allowed me to figure out how. 2 years later, it still works great
Old Apr 1, 2014 | 04:54 AM
vipervick's Avatar
vipervick
Holy grail of finds, thank you!!! I had actually watched the 2011 videos from fondupot. Not that helpful, but getting closer.
dantheman88125
Apr 15, 2007 10:41 PM
voodoosmooth
Mar 28, 2005 08:04 PM
shannmann
Jun 22, 2004 10:47 PM
chuck641
1978 - 1996 Big Bronco
Feb 27, 2004 08:33 PM
