Bronco II Ford Bronco II
5 speed trans
Old Mar 27, 2014 | 09:18 PM
rogerpruett's Avatar
rogerpruett
5 speed trans
Bought a 1988 Bronco II. Runs great, no smoke.
Trans was a little noisy in 1-2-3 gears. Pulled drain plug. Automatic fluid came out. On identifying this trans, it is an FM146, with transfer case.(center drain plug)
Put 80-90W gear oil back in.
Question- u think bearings are shot because of Trans fluid?
Old Mar 28, 2014 | 07:28 PM
smalltrucker's Avatar
smalltrucker
Should be alright, found this where it happened to someone else.
Dave
ATF in FM146? - The Ranger Station Forums
Old May 19, 2014 | 02:48 PM
RA31925's Avatar
RA31925
Yep, the FM145/FM146 used gear oil. Previous owner probably thought it was an M5OD, which uses ATF.
Hard to say whether there's been damage. Is the drain plug magnetic and if so, did you see anything ugly? How does the tranny sound and perform with gear oil?
Rogue_Wulff
1983 - 2012 Ranger & B-Series
Nov 2, 2011 08:15 PM
newfordguy88
Oct 9, 2006 02:23 PM
b2man
Bronco II
Apr 3, 2004 05:33 AM
824x4ride
Mar 11, 2004 10:30 AM
