Bronco II Ford Bronco II
Need help identifying transmission
Old Mar 30, 2004 | 12:56 PM
b2man's Avatar
b2man
I have 1985 Bronco II 2.8 v-6 w/ 5 speed trans., 4x4, I need to identify my transmission and determine what fluid to use. I'm not sure it is stock transmission and cant find any markings. I do know I have a 13-50 transfer case and think I may have a Mazda trans. My trans has a bottom drain plug with 14 bolts on bottom cover.Can someone tell me what I have and what fluid (ATF or Oil) should i use? Your help will be greatly appreciated. THANKS.
b2man
Old Mar 30, 2004 | 05:35 PM
GrayRanger4x4's Avatar
GrayRanger4x4
Your trans is a FM146.and it takes gear oil SAE 80W.The t-case is a 1350 and it takes Dexron II ATF if it is the the t-case that came in the truck.
Old Apr 3, 2004 | 05:33 AM
b2man's Avatar
b2man
I appreciate your reply grayranger but after further examination and using a mirrow, I found a part No. E57A 7003 PA. Info I find on that number is a Toyo Kogyo. Can anyone tell me anything about it. Thanks.
