What to do with te head cross-over pipe
Old 03-27-2014, 03:24 PM
reamer's Avatar
reamer
reamer is offline
Running a eddy 4v and non EGR intake, The carb has the PCV fitting in the front, so my passenger side-rear PCV has to be routed it that.
But I still have the cross-over pipe from the heads installed.
It, and the valve on top are brand new, caus I "thought" getting the emission crap done was going to be easy.
Now that all that stuff is gone, what to do with the crossover pipe and valve?
Can I just route it back to the original spot on the exhaust, or is that useless?
Should it be, (is it beneficial) to route it to the PCV line?
Should I cap it off at the valve on the crossover, and cap off where it joins the exhaust pipe?
Old 03-27-2014, 03:51 PM
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
W/o the various controls and the AIR pump the system doesn't work. So I'd pull the manifold and plug the holes with short 5/8-11 bolts and a washer under the head. And a bit of high-temp RTV would help seal it.
Old 03-27-2014, 04:17 PM
reamer's Avatar
reamer
reamer is offline
Wanna buy a brandie-new crossover pipe and valve?
Old 03-27-2014, 04:20 PM
Gary Lewis's Avatar
Gary Lewis
Posting Legend
The M doesn't run one. Sorry.
smcdonald001
05-06-2016 08:44 AM
JohnBOV43159
03-24-2010 04:22 PM
aircraftfixer
01-26-2007 05:48 PM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
08-07-2003 09:06 AM
cepfire
05-18-2003 09:52 AM
Quick Reply: What to do with te head cross-over pipe
