Need help having a fuel problems
Old Mar 27, 2014 | 08:37 AM
TK8569's Avatar
TK8569
I own a 1995 f150 that just yesterday (3/26/14) started to appear to use ALOT more gas like 3/4's of tank in only 95.6 miles I have no leaks and she isn't idling any higher then norm. She does have two tanks I'm seeing this on the back tank can't see the front is will not read.
Old Mar 28, 2014 | 02:52 PM
baddad457's Avatar
baddad457
Fill it up, run it then fill again and divide the gallons used into the miles driven. You cannot rate fuel mileage off the gauge, they're not that accurate.
Old Mar 28, 2014 | 08:29 PM
Conanski's Avatar
Conanski
Does the front pump work.. meaning will the motor run on it? Fuel transfer between tanks is very common with these trucks so unless your fuel gauge suddenly went berserk I'd bet your fuel is now in the front tank.
Collision
Apr 25, 2016 01:34 PM
jonrjen
6.7L Power Stroke Diesel
33
Aug 21, 2014 12:05 PM
jor1369
2009 - 2014 F150
Jun 15, 2014 09:02 PM
Kcorrie
22
Mar 30, 2014 07:19 PM
cclc1021
Nov 29, 2006 10:16 PM
