Downpipe Loss Measurement?
Old Mar 26, 2014 | 11:49 PM
Bob_T's Avatar
Bob_T
The previous owner had a problem with the egpbv sticking closed and I'll be deleting it soon. The darn downpipe just looks inefficient and I know it's pretty much a standard upgrade when working on the backpressure valve system.
I know that everything that looks bad isn't always necessarily bad. Has anyone measured the actual pressure drop across that downpipe? Any real numbers for the loss, like in psi or inches of water? I'm sure not trying to second guess the conventional wisdom, but I'd like to see some numbers. If no one has done it I have a pressure transducer, I can tap a couple of ports and I'll give it a try.
Thanks,
Bob
Old Mar 27, 2014 | 07:17 AM
1994F2507.3L's Avatar
1994F2507.3L
I think you should do it it'd be interesting to put some numbers to what is typically measured by the butt dyno
Old Mar 27, 2014 | 07:26 AM
Bob_T's Avatar
Bob_T
Yeah, I think it will be interesting. I didn't want to re-invent the wheel, but if it looks like no one else has done it, I'll get after it.
Has to be done sorta scientifically because I think low pressure measurements are tricky and I don't want to be spreading false numbers around.
Bob
Old Mar 27, 2014 | 07:44 AM
DIYMechanic's Avatar
DIYMechanic
I don't know that anybody has done actual measurements in the past, but it would be cool to see it done! I just cut my old stock piece out a couple nights ago so if it would help for any measurements, etc let me know and I'll get you some numbers. IIRC when I have measured them in the past I have found the stock DP to be approximately 1x4" and clearly the 3" would be 3" diameter. just comparing those two from area alone is pretty telling. Clearly a 1x4 pipe has an internal are of 4 in/sq whereas a 3" round pipe has an area of 7.065 in/sq. That's a pretty sizable difference. I know that's just a rough guesstimate but you get the idea.
Old Mar 27, 2014 | 07:56 AM
CampSpringsJohn's Avatar
CampSpringsJohn
While size isn't everything (where have we heard that before) the flow dynamics also needs to be taken into account. Just looking at the factory downpipe to me, looks very inefficient. Some actual flow numbers would be interesting!
Welcome to FTE!!
Old Mar 27, 2014 | 11:44 AM
richdawg's Avatar
richdawg
Welcome Bob, Great way to start out.
I am Subscribed
Old Mar 28, 2014 | 12:52 AM
oldbird1965's Avatar
oldbird1965
Welcome Bob, this is interesting.
Old Mar 28, 2014 | 07:02 AM
Bob_T's Avatar
Bob_T
The truck is a '96 and as far as I know is completely stock. My initial plan is to install a port somewhere on the egbpv housing, after the valve is deleted. Then measure the exhaust pressure of the complete exhaust system at say 2500 RPM. Then remove the muffler and repeat the measurements. Then remove the cat and repeat again, which should show just the backpressure on the downpipe. Then install one of the round aftermarket downpipes and repeat the measurement. I want to take several measurements at each point to make sure they are all within a reasonable range.
I'm not sure what to expect as far as backpressure on just the downpipe. I have a Fluke PV350 digital pressure measurement sensor but it's +/- 0.3 psi accuracy. If it reads 0.5 psi then the actual pressure could be from .2 to .7 psi and I'd like to do be more precise than that. I ordered a 0 to 3 psi analog dial gauge to back up the Fluke.
The above is just my initial poorly thought out plan and I'd appreciate any comments or suggestions.
Bob
Old Mar 28, 2014 | 07:22 AM
DIYMechanic
I think it sounds like a good plan. If you intend to put the port in the EBPV housing, you may consider drilling and tapping the freeze plug that you install to block off the hole in the housing for the shaft. The thing I'm not sure of though is how you would be best to install the port so the gasses flowing past it don't create a Venturi effect and skew you readings.
Old Mar 28, 2014 | 08:43 AM
Bob_T's Avatar
Bob_T
Yes, that's one of my concerns too. I have a friend who measures steam flow and pressure in pipelines at power plants and I'll get some advice from him.
johnday
Exhaust Systems
Sep 23, 2013 03:17 AM
TheTowingCowboy
Jul 31, 2009 08:32 AM
cbfomoco
Jan 17, 2006 11:04 PM
Carlene
1947 and Older Ford Trucks
16
Jan 7, 2006 10:58 AM
