Fuel Pump Issues
Old Mar 26, 2014 | 06:38 PM
caleballen95's Avatar
caleballen95
Fuel Pump Issues
Alright, so we replaced the fuel pump on the ole 76 f100, its a mechanical fuel pump. We go to start it (didn't run previously, it cranks but wont turn over). Took the fuel line off at the carburetor and put the hose in a bottle to see if fuel is being delivered...nothing. Even replaced the starter thinking maybe it wasn't turning fast enough. Could the line be clogged and gummed up? It's sat for 7-8 years and I believe the previous owner ran it out of gas. I'm dumbfounded. Any ideas to why I'm not getting fuel?
Old Mar 26, 2014 | 06:43 PM
turbohunter's Avatar
turbohunter
Yes
The lines from the tank to the pump can clog up with resin and garbage. The inlet filter inside the tank comes apart and turns into strips of crud that can be sucked into the line also.
Sorry but you're gonna have to remove and check it all.
Old Mar 26, 2014 | 08:32 PM
VocaTexas's Avatar
VocaTexas
How I start an engine that hasn't been run in years or has a possible fuel issue:First, I check the engine over to make sure it is in condition to run. Oil, all the important parts are there, etc. Then I disconnect the fuel line from the tank at the fuel pump, that way I don't suck crud into the fuel pump. Then I take my PROPANE cutting torch (DO NOT USE ACETYLENE) and drop it into the throat of the carburetor. Turn the propane on full and hit the starter. The engine should be running within a couple of seconds. If it is, then I know the ignition system is functioning, at least well enough to run. Then I start checking out the fuel system.
Starting fluid works, but it's expensive and I don't like using it if I don't have to. Pouring gas into a carburetor is a good way to start a fire. I've always got propane for my torch, it's relatively cheap, it's safe, and it's easy. JUST DON"T USE ACETYLENE!
Old Mar 26, 2014 | 08:46 PM
Nortex's Avatar
Nortex
This happened to me not too long ago. Same exact situation. I changed the filter up by the carb thinking that would be enough but it wasn't. So then I changed the 2nd/other filter further back and I found a bunch of crud that had backed up in the line behind the filter.
Cleaned it out, changed the filter, and I was good to go.
Old Mar 26, 2014 | 09:06 PM
caleballen95
Was the second filter by the frame rail or in the fuel tank itself?And, thanks guys for the response, using the propane tank.....that sounds like a good idea! Couldn't you also use a fuel cell from perhaps a mower straight to the carb and run it like that, letting gravity be the pump?
Old Mar 26, 2014 | 09:11 PM
Nortex's Avatar
Nortex
Yes, by the frame rail by the inner wheel well.
Old Mar 26, 2014 | 09:22 PM
caleballen95
Thanks
Thank you sir
CopenGrizz01
21
Oct 27, 2018 08:53 AM
Mikey G
Aug 12, 2016 10:00 PM
Toakley123
19
Feb 12, 2016 09:48 PM
keyul
May 15, 2011 10:38 AM
Chevy_Monza
Apr 3, 2003 06:31 AM
