Sponsored by: Real Truck
HP 4x4 SD build
Old Mar 31, 2014 | 09:26 PM
  #61
Lubbockguy1979's Avatar
Lubbockguy1979
If the front is a dana 60 there are several lockers avalible. If its a dana 50 not so much. Now for the rear a detroit locker is the way to go. Hard to be the old reliable and given your wheelbase it should have good manners. Also some one does make a electric locker for the factory trucks so that should be out there.
Old Apr 1, 2014 | 07:19 AM
  #62
lhill1995's Avatar
lhill1995
I called a company that deals is differentials but they had no record of anything electronic selecting. You can only get the entire axle assembly from ford according to the ford parts guy. Besides that I ordered the electronic locking rear diff on my wife's new truck (got stuck with crappy 3.31 gears, thanks ford), and I am not supposed to use it unless the truck is unloaded and on a slick surface. They actually made it sound weak to me. I wish they would have before I ordered it. Auburn gear ECTED is made to handle abuse and is a limited slip when not engaged. The versions made for other assemblies like the dana 60 are only about $200 more than a True Trac and the ability to selectively lock it is nice. I do not like ARB because I have a hard time with air fittings.
Old Apr 1, 2014 | 07:44 AM
  #63
lhill1995's Avatar
lhill1995
Well I guess I will keep y'all updated. Do y'all want a build thread on the suspension lift install? Or just the engine and tranny when I do them? Or put it all together?
Old Apr 1, 2014 | 10:54 AM
  #64
lhill1995's Avatar
lhill1995
Just curious, I have read several threads on swapping out the 5.4 for the 6.2 and everyone says it isn't possible without a wiring nightmare, and just leaves it at that. Apparently the tranny and motor mounts are the same bolt pattern. Wouldn't it be possible to build a custom intake to fit the electronics from the 5.4 on it? Then is there any way the cam phaser system could be deleted for a standard cam. I know the supercharged 5.4 is the easy way to go and I will be happy with that but eventually I will want to grow. When I build this engine it will be on par with a stock 6.2 (because reliability is important) so I am curious if it would be possible for the 5.4 computer to run the 6.2 with 5.4 electronics and no cam phasers with proper programming. Maybe this would be the topic for another thread but this is the one I have open and I would like to know because the 6.2 has a bunch of room to grow where the 5.4 is tapped out due to valve shrouding, small bore spacing, and long stroke.
Old Apr 1, 2014 | 11:30 AM
  #65
Bigpipes 35's Avatar
Bigpipes 35
There are lots of suspension installs on this forum but next to zero 5.4 builds, my vote is for the engine build thread. As far as the 6.2 swap I think you are in unchartered territory as far as swapping one in place of the 5.4.
Old Apr 1, 2014 | 11:38 AM
  #66
lhill1995's Avatar
lhill1995
Yea I was just hoping somebody with tuning experience or knowledge of electronics might stumble across the question.
Old Apr 1, 2014 | 11:51 AM
  #67
lhill1995's Avatar
lhill1995
Livernois has cam phaser lockouts, guess that takes care of the cam phaser question.
Old Apr 2, 2014 | 05:46 AM
  #68
lhill1995's Avatar
lhill1995
Well I got the idea yesterday to search the mustang forums, and there has been at least 1 6.2 swap into a stang using a modified wiring harness. Apparently it was pretty difficult. Then the tuning was an issue. Apparently the torque management system was a pain.
Old Apr 2, 2014 | 06:01 AM
  #69
redford's Avatar
redford
FTE Leadership Emeritus
You need to get with these guys on the svtperformnce.com forum.
"6.2l 4.02x3.74 379" un ported factory head's, sheet metal intake 105MM TB, free Boss injectors, short tube headers, factory lift .510 lift cams shorter duration, 10.1:1 CR factory twin plugs stayed. 2003 crown Vic PCM used with CNC'd cam timing sprocket 4.6l sensors retained with new harness. PCM calibrated for engine size. 6500RPM 521.4HP
all together I paid a little under 4K.
5.0l vs. 6.2l
Old Apr 2, 2014 | 12:31 PM
  #70
lhill1995's Avatar
lhill1995
Thanks I missed that one. Sounds like he did what I was talking about, but I'm waiting to hear back. If it's just fab work then it doesn't seem that difficult but wiring is a pain.
Old Apr 2, 2014 | 05:54 PM
  #71
th3jared's Avatar
th3jared
Post a picture! !!
Old Apr 4, 2014 | 08:25 AM
  #72
lhill1995's Avatar
lhill1995
This is it a month ago in Cushing Oklahoma. I should be going home in a few weeks and will post a picture of the truck after the install. Then I will do a build thread on the route I go. From what I have read so far the 6.2 is becoming more interesting as it in stock form running 87 octane puts out more than the procharged 5.4 running 91. Then there is room to grow with the 6.2 while the 5.4 is tapped out unless you raise your powerband. A high powerband sucks for a truck though.
Old Apr 4, 2014 | 08:28 AM
  #73
lhill1995's Avatar
lhill1995
It will not let me post a picture from my iphone. I can't even find the option.
Old Apr 5, 2014 | 08:09 AM
  #74
lhill1995's Avatar
lhill1995
Last edited by lhill1995; Apr 5, 2014 at 08:10 AM. Reason: I did not remove or delete the image
Old Apr 5, 2014 | 08:15 AM
  #75
lhill1995's Avatar
lhill1995
Anybody body know why it says this when I post an image from photobucket?
rick700raptor
Jan 2, 2012 02:42 PM
reddogracing
Oct 19, 2011 02:19 AM
Pickupman2004
Oct 29, 2007 05:39 PM
7.399
Nov 4, 2006 10:03 PM
grunvs1
Modular V8 (4.6L, 5.4L)
Sep 1, 2003 09:24 PM
