Sponsored by: Real Truck
Adding TPMS
Old Mar 26, 2014 | 01:29 PM
Shorthair49's Avatar
Shorthair49
Adding TPMS
I have a 2013 F350 XLT, CC, SRW, 6.7L. It did not come with TPMS as an installed option. What would be required to install an OEM TPMS? If that is feasible, I assume i would need to have some programming enabled to make it active. Does this make sense, or would be it better to just add an aftermarket system like one from TST?
TIA,
Shorthair49
Old Mar 26, 2014 | 06:56 PM
05F250DSL's Avatar
05F250DSL
A 13' xlt doesn't have tpms? Are you positive I thought it was a standard feature these days. Most every car since 08' has them Evan a flipping Kia these days they come standard on. But a 50k truck doesn't. That just ain't right. Scroll through your info center or when you first turn on the key look for a light that looks like a tire and exclamation point.
Old Mar 26, 2014 | 07:18 PM
Shorthair49
I know, I was a little surprised as well. I've scrolled through the info center and setup several times and seen nothing of it. I'll have to dig out the Maroni and check through it as well.
Old Mar 27, 2014 | 08:18 AM
Raymond's Avatar
Raymond
Veteran: Navy
I far as I know all vehicles manufactured since 2008 are federally mandated to have a TPMS.
Old Mar 27, 2014 | 08:24 AM
Shorthair49
Was the requirement for all GVWR < 10000 lbs? Thanks for your replies fellas.
Old Mar 27, 2014 | 09:17 AM
snelldawg's Avatar
snelldawg
You have to have it....let a bunch of air out of one tire and you should see the message display.
Old Mar 27, 2014 | 10:42 AM
JandC's Avatar
JandC
My 2012 F350XLT just has the idiot warning that comes on when a tire is really low. I installed a TPMS on my 5th Wheel that gives me constant readings on exact tire pressure and air temperature inside the tire. The system I purchased came with 6 sending units (flo thru) that went on the valve stems. I only used 4 for my 2 axle 5th Wheel and plan on putting the extra 2 on the rear tires of my F350.
Old Mar 27, 2014 | 10:51 AM
Shorthair49
Thanks JandC. I must just have the idiot light. My owners manual indicates that it is on the truck. I would like to do like you did and add a TPMS for our 5er also. What system did you go with?
And thanks to everyone for your responses.
Ed
Old Mar 27, 2014 | 07:31 PM
Kdr358's Avatar
Kdr358
Ed
You are correct, the TPMS system in these trucks alerts you which tire is low accompanied by the light, pretty minimal.
I think a real-time TPMS monitor would be a great feature to have!
Old Mar 27, 2014 | 08:19 PM
JandC's Avatar
JandC
I got the TST Model 507 with flow through monitors. I got it on sale but can't recall the price. Camping World and numerous places have it. The kit I purchased came with 6 sensors, but I have heard some guys getting ones that only have four. The monitor for inside the truck is about the size of an I-Phone 5. You set your high and low limits for each tire monitored and the pressure ranges you want. It any tire goes outside those limits the alarm goes off and believe me when I tell you....you will hear it! It constantly goes from one tire to the other and shows both pressure and temperature in that tire. The new 507 systems are much better than some of the older ones because the batteries last for at least 2 years and you can replace them yourself, unlike the old units that had to be sent in for replacement.
RA12726
Mar 25, 2019 11:58 PM
ThumosRacing
Aug 7, 2017 12:18 PM
PNGento
Apr 30, 2017 04:14 PM
ansfdev
Apr 11, 2017 05:49 PM
katesdad
6.7L Power Stroke Diesel
Feb 19, 2012 12:23 PM
