Is there anyone in Hot Springs, AR who has a scanner to check and see what codes the transmission is putting out? Maybe a reputable transmission shop, member? Trans shifting hard 1st-2nd, OD off light flashing. Text ok 870-692-7850 Thanks, Billy
Might fire off a PM to cookie88; while he doesn't live in Hot Springs...he might know someone in the greater LR/Hot Springs area with a code reader. Or at least a shop that won't lead you astray. I've got AE-Ford, but calling FSM home doesn't exactly help you out much....wish I was closer.
