03 Expedition Electrical Gremlins
Old Mar 26, 2014 | 01:48 AM
ron0708's Avatar
ron0708
I love this truck but I am slowly losing faith in it. The truck is a 03 Expedition Eddie Bauer. Ive searched for hours on the issues im having. Ive done one of the fixes but didnt change anything. So this is what is going on. Randomly when i open any door or the lift gate my stereo will come on with the key out of the ignition. This also happens when I use the unlock button on the key fob sometimes. The other issue is that when I turn off my truck the radio will say on randomly. I have made sure that it has nothing to do with my door triggers. All doors set off the door ajar on the dash message center. The only fix that I came across was the violet wire that needed to be resolderd in the drivers sill. I did that and nothing changed. I am at a loss and could use any info possible.
Old Mar 27, 2014 | 12:32 PM
dclack's Avatar
dclack
Turning on when you open the door is strange, but the radio is suppose to stay on after you turn the engine off until you open the door. My guess is that something is wrong with that circuit. If you have a good wiring diagram, you should be able to find that circuit at the radio and disable it so that it only turns on with the key.
Vanniek71
Aug 9, 2018 08:57 AM
dwildmanj
1983 - 2012 Ranger & B-Series
Apr 26, 2005 03:11 PM
ugotkern
Oct 22, 2004 06:40 AM
oakcrkcynranch
Electrical Systems/Wiring
Jun 30, 2004 09:20 PM
RangerRuss
1997 - 2003 F150
Oct 31, 2003 06:28 AM
