Cold Start PIS 160/30...new video added page 2
I've probably got 200 or miles on since the swap. I've been told smoke is normal.
There's been a long running discussion on PSA about 238/100's hazing at idle. It makes for a good read. They bring up the AIH as well. But I was under the assumption that the AIH is active in a very limited set of parameters.
I myself, with my very very limited knowledge, think that the PW could be pulled back a bit and solve that.
A see a lot of that disappear right away - as in steam on a cold morning. Gassers will steam on days that cold - just get behind someone at a light and you'll see it.
I'm not saying that's the whole issue, but that can account for a significant amount of the "smoke". Other than that, there are two things I have experienced that can cause nasty smoke at cold startup: Tuning, and a bad stick. I had a smoker and I pinned down the offending stick (they usually show other symptoms as well, when not working right). I swapped it and the smoke went away... but I have a 9th matched injector to try such things.
I haven't watched mine in a while, because I almost always use auto-start on cold days, which have been many this year. When I first got the 160/30's, I was watching a lot of the time due to the fact that I was coming off of almost a year of hard cold starts, hence the injector purchase to begin with. I noticed there was white smoke right after start-up for approximately 45 seconds, maybe a minute. It was about 1/2 to 3/4's the amount yours is showing in that video, Dan. I was trying to see if yours went away in about the same time, but you edited the video so I am not sure. So I would say it is similar. To be clear, I too have reman'd PIS 160/30's and DP tuning.
I will say, although it hasn't been as cold here lately as in January, the truck does fire up much better, hardly cranks at all and it's running. Before the injector swap, she was a wee bit temperamental....liked the umbilical cord.
If it goes for 5 minutes, I don't think that is normal. Like I said, mine is 45-60 seconds, and honestly, I am not sure that is really "normal". It is going down to 20 here tonight so I will check mine in the am, and maybe, MAYBE, go out there and video it when I start it and get a better idea of timing.
Deal?
