79 F100 sbf 302 timing problem
#31
I was just suggesting trying a whole different carb to rule out/confirm the actual carb on the motor now is the problem. If the truck acts the same with a different carb then the problem is most likely somewhere else, if it acts fine then he knows the problem is internal in the carb somewhere (with the floats or filters). Since he alredy has the extra carb I thought it'd be easy to give it a try.
#32
for some reason i assumed it was a new 1405.
even at that, stuff happens and it's an easy swap just to elminate a problem with the carb.
to the OP:
i'm really surprised that it is falling flat once you hit the secondaries.... the air valves generally preclude any bog when you get into them, and even if it is way rich, it just won't pick up any power on the secondaries, but it usually runs OK.
even if your intial guess turns out being correct, you now have all the right pieces in place to be able to troubleshoot and tune properly. All your work will pay off in the long run regardless of what is causing the initial problem.
as a side thought, i wonder if unhooking the secondary linkage would allow you to make sure that the timing and fuel delivery system is working well first. This would allow you to tune the primaries to get them dialed in without having the secondaries as an additional variable to contend with. Then, once you got the primaries where everything runs really well, then you can hook them back up and tune the secondaries by themselves.
just a thought.
#33
that's a good idea ....
to the OP:
just a thought.
to the OP:
just a thought.
jasindude1
11-03-2019 11:37 AM
LilBear'65
16
03-12-2015 10:16 PM
RocketmanVT
12-30-2012 05:04 PM
