AOD trans No reverse
Old Mar 24, 2014 | 06:39 PM
Fordman F100's Avatar
Fordman F100
Hi .I got this 83 Ford F100 5.0L V8 with 2 ventury carb and an AOD trans . I has no reverse right now and wondering what it might be. A couple of weeks ago went to Adrian MI to pick up an newer used engine for the same truck and when i got to the guys house and tried to back up the the garage to load engine , Nothing happened as a shifted into reverse. Also the same morning when i went to my doc appointment reverse worked great and in the afternoon it did not. That was embarrassing to say the least. Got the engine and got home ok. All FWD gears work just fine. It also has engine braking when shifted into low. But no reverse. Last Thurs. went to car wash and had to back into stall. was not easy but it did with about 3200 RPM and slowly creeping backwards. Any ideas are greatly appreciated. Thanks.
Old Mar 25, 2014 | 06:00 AM
redford's Avatar
redford
FTE Leadership Emeritus
Thread moved to 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks forum.
Old Mar 25, 2014 | 10:14 AM
Brnfree's Avatar
Brnfree
Low fluid?
Old Mar 25, 2014 | 06:01 PM
Fordman F100
No , fluid level is right where it needs to be.
Old Mar 26, 2014 | 04:43 AM
tempest411's Avatar
tempest411
Here's some notes I found online recently that may help you. I've never gotten into them myself, but I did a fair amount of reading about the AOD as I've been having some issues recently..
File Type: pdf
Old Mar 26, 2014 | 04:45 AM
tempest411's Avatar
tempest411
And this...
File Type: pdf
File Type: pdf
Old Mar 26, 2014 | 07:22 AM
Fordman F100
Thank you very much , i think that will help some , nice pictures of the trans VB and other info. Thanks.
schmeck
2004 - 2008 F150
Jun 25, 2015 05:53 PM
DT 466Man
18
Oct 5, 2013 03:09 PM
pud
Dec 29, 2008 02:21 AM
*92flareside*
Dec 10, 2005 08:17 PM
otto
Jan 24, 2001 10:58 AM
