Video Recommendations?
Old Mar 24, 2014 | 01:49 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I am looking for video recommendations from the brotherhood. Any newbies need help with something I dont already have covered?
I have a few ideas I am working on, but would welcome any input.
Working Ideas:
MPG Checklist
Dash Command (or similiar OBDII on iOS)
Aim Headlights
7.3 Sensor List
General Maintenance
Anyone have anything to add or something they want to see? The videos are for the brotherhood, so I figure I might as well get some input!
/TreySpooner
Old Mar 24, 2014 | 02:04 PM
Tugly's Avatar
Tugly
Ohming out the 42-pin connector and the glow plugs, and properly testing the GPR. There are way too many threads going into great depth for such simple and common tasks. Everybody would just link to that instead, and you'd get a lot of hits.
Old Mar 24, 2014 | 02:09 PM
Lambert01's Avatar
Lambert01
thats weird, i was just reading Tugly's recent post on the 42 pin connector and which ones to ohm and thought it would be cool if there was a video of it.
Old Mar 24, 2014 | 02:41 PM
timmyboy76's Avatar
timmyboy76
if they can get the turbo out...then a vid on rebuilding it. I got one if need be..(already rebuilt and ready to drop in) if your down foe it
Old Mar 24, 2014 | 02:55 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Those are great ideas. Simple yet effective. Added to list.
A/Ox4's Avatar
A/Ox4
9 ECHO 1
PM sent...
Old Mar 24, 2014 | 02:56 PM
trekbasso's Avatar
trekbasso
This might be hard, but show replacing the seals inside our 4x4 hubs. The expensive one, that needs to be pressed onto the outer axle, to repair leaking air issues. Guzzles showing the hub work doesn't detail the seal replacement. It is hard to know where to position it.
Old Mar 24, 2014 | 09:38 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Man, I just did this Thursday, wish this was brought up last week. It was pretty straight forward though...
Old Mar 25, 2014 | 09:44 AM
trekbasso's Avatar
trekbasso
Yeah, but I fear I didn't get the seal/axle relationship perfect. I had problems getting the snap ring and thrust washers on, too tight. Hard for me to know where to position the seal exactly.
Old Mar 25, 2014 | 06:32 PM
F-250 Super Duty
The factory seals on mine were in two different places. One seal was flush with the axle the other was about a 1/16" from being flush. When I I put the new seals on both ended up about a 1/16" from being flush.
Once that was done I put the thrust walker on and unit bearing back in placed and used the unit bear to seat the axle. No problems at all, you just have to tighten the unit bearing down in equal increments with the four nuts.
Sorry for the hijack Trey.
Old Mar 26, 2014 | 09:29 AM
DavidE's Avatar
DavidE
Assessing Turbo Play
Process and steps to check for excessive play in the Turbo. Needed bfore deciding to remove it for repair or replacement. Thanks
Old Mar 26, 2014 | 09:50 AM
trekbasso's Avatar
trekbasso
Me to Trey. Back to the regular scheduled programming.
Old Mar 26, 2014 | 07:40 PM
t.scottNDU's Avatar
t.scottNDU
Yeah, I'd really like to see a turbo removal/rebuild/reinstall. Could make an opportunity for a short series or one long episode.
And Tugly's idea is very nice as well. Such simple things I haven't seen covered in videos, with the clarity of yours at least.
Old Mar 26, 2014 | 09:12 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I like the idea of the turbo removal video(s). I just don't want to pull mine off for no reason. If someone near me wants to theirs I will have an opportunity to make one, but until that time it will have to wait. I've got 3 7.3Ls near me that I use for videos including mine.
I'm trying to find a 6.0 near me to branch into those as well.
Old Mar 26, 2014 | 09:32 PM
sand_fiend's Avatar
sand_fiend
Trey, I have a set of dorman up pipes to go on soon.
I also am going to do a turbo rebuild kit, new wheel, boots and plenum inserts..
probably in the next month or so..
ithaca1230
Feb 28, 2015 10:36 AM
flavo
Nov 3, 2013 08:45 PM
Tater50
13
Dec 14, 2010 06:38 PM
spinge
Sep 22, 2007 01:47 PM
Fatshot
Mar 23, 2004 10:59 AM
