master cylinder
Old Mar 23, 2014 | 06:26 PM
1994 ranger ford's Avatar
1994 ranger ford
master cylinder
have a 94 ranger 2 wheel drive, have a single bowl mc, can I get a dual bowl to fit right in. thanks pete
Old Mar 23, 2014 | 07:25 PM
smalltrucker's Avatar
smalltrucker
It would be a single reservoir but a dual circuit. Been federal law since the 60's. You are talking brake master?
Dave
Old Mar 24, 2014 | 05:09 AM
1994 ranger ford
brake master
yes, I was talking about brake master, concern of single bowl, my buddy has a 99 ranger single bowl, had a pin hole leak front driver side, lost all his brakes, pretty scary, why would they put a single bowl? pete
Old Mar 24, 2014 | 07:55 AM
tomw's Avatar
tomw
Why would they put single bowl? Cost. In addition, it should have still kept the brake fluid in the 'other' side of the system that did not leak. When you step on the pedal, the pistons in the master move, trapping the fluid as the piston passes an orifice. The fluid on the 'other' side should not have disappeared, and should have still kept the brakes working.
The 'failure' was likely just what you get brake-wise when you lose the disk half, long stopping distances. I'd bet a donut that the operator still had brake pedal during the 'failure'.
Take a look at a cutaway master, and you'll see that a single cavity reservoir should work fine.
tom
Old Mar 24, 2014 | 12:50 PM
Hank85713's Avatar
Hank85713
his rear brakes were probably typical in that they were way out of adjustment and thus the feeling of no brakes. Supposedly these have self adjusters but if you dont periodically do the stops to keep adjusted they will get way out and then you are using the fronts more than required.
Old Mar 24, 2014 | 03:30 PM
1994 ranger ford
brake master
thanks for info guys, I will go over and check it out, so he should still have fluid in the back brakes, will check...thank you pete
Old Mar 24, 2014 | 05:28 PM
03 Maz B23's Avatar
03 Maz B23
your bud probably blew a metal or rubber brake line which lowered level in master cylinder
abe
Sep 28, 2012 11:22 AM
xltlariat87
Jan 21, 2009 07:05 PM
WVBrady
Mar 6, 2005 08:09 PM
ham4ever
Nov 9, 2004 02:15 PM
Aarkie
Sep 3, 2003 10:17 PM
