master cylinder question
Old Sep 27, 2012 | 10:07 PM
abe's Avatar
abe
I was returning from the landfill after dumping a big load of brush and yard waste and my brake pedal went tot he floor. I made it home all right. When I pumped the top on the master cylinder the rear reservoir was empty.
Is the reservoir nearest the firewall for the rear brakes? I would assume but... you know about the word assume....
I added brake fluid but when I pumped the pedal it still seemed spongy and went to the floor. I do not see any sign of fluid leaking at the wheels.
I will get under the truck tomorrow. Would you suspect a hole in the brake line?
Thanks!
Old Sep 28, 2012 | 02:38 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Does your F350 have 4 wheel drum brakes? Or does it have optional dual piston front disc brakes?
Old Sep 28, 2012 | 06:51 AM
willowbilly3's Avatar
willowbilly3
Generally the rear reservoir is the front brakes on a dual system. It will also be the largest. It shouldn't be hard to look under the truck and see where the fluid had escaped. Of course it will still be spnongy after you add fluid as there is trapped air in there. After you fix the leak you will need to bleed the system.
Old Sep 28, 2012 | 10:53 AM
NumberDummy
If brake fluid is leaking into the booster, it will be difficult to spot.
Old Sep 28, 2012 | 11:22 AM
abe's Avatar
abe
Thanks for your help everyone. I crawled under the truck this morning. I looks like the leak is somewhere near the left front wheel. I havent seen the exact location but I will have to have the whole line replaced. I don't think it is the flexible line to the wheel.
mkoser
Mar 13, 2010 01:11 PM
78ford f250
Dec 29, 2009 12:09 PM
kermmydog
Nov 6, 2007 08:11 PM
idifamilycab
Jul 9, 2007 07:04 PM
TXF250
Aug 10, 2004 04:07 AM
