Door Striker Pin
Old Mar 23, 2014 | 08:28 AM
zingerr's Avatar
zingerr
Door Striker Pin
Hello all, I have an issue with my door striker pin, i've noticed over the last couple of months my doors have been very hard to close. I've read a thread that said something about there being nylon around the pin but I don't have it. It is just bare metal. The other thing is when I pull the old one out does something fall out on the back of the pin where the threads are? I'm thinking that there is some sort of washer and it may fall off... Any help is appreciated!
Old Mar 23, 2014 | 08:39 AM
bucks77ford's Avatar
bucks77ford
Ya, there is a bushing around it. The striker will just thread in like a bolt. Nothing will fall back. The striker is made to be adjusted so the backside nut will be loose but won't go anywhere.
Old Mar 23, 2014 | 08:43 AM
march's Avatar
march
The striker should have a nylon (plastic) bushing on it. Nothing will fall off the backside. There's a reinforced area that it threads into. There should be a large washer between the striker and the door frame.
Usually a missing nylon bushing will cause the door to be loose and rattle while you go down the road. It shouldn't be hard to close unless you have some type of misalignment going on.
Old Mar 23, 2014 | 10:04 AM
mikeo0o0o0's Avatar
mikeo0o0o0
If needed, new striker bolts are still available in the HELP! section at the parts store.
f100today
Mar 31, 2017 07:09 AM
Treacy
Jul 6, 2016 04:47 PM
maxride
Mar 21, 2015 08:12 PM
Copedawg
23
Oct 19, 2011 06:19 PM
ucmeflyby
1978 - 1996 Big Bronco
Oct 12, 2004 02:55 PM
