rod fell out. Help
Old Jul 5, 2003 | 03:52 PM
ranger429's Avatar
ranger429
rod fell out. Help
if you bumped the motor over with no push rods on the valve lifter you very well may have pushed the lifter right out of the lifter hole. did you get a flashlight and look down the hole in the head to see if you can see the lifter? if there was not a lot of buildup on the lifter at the base (by the camshaft) it could have easily pushed the lifter out and that is why the push rod will want to fall in.
there is a reason why you bent two pushrods. were the bent pushrods intake and exhaust on one cylinder? have you checked the timing chain and gears? does it have the plastic camshaft gear on it? may have jumped a gear. did it backfire at all when this happened? have you got the oil pan off? did you check to see if a rod had broke or piston pin broke?
keep us posted
tecgod13
19
Feb 3, 2017 09:19 PM
88rangerman68
1983 - 2012 Ranger & B-Series
Nov 3, 2016 11:05 PM
Jlhearn
Oct 11, 2016 02:27 PM
ddabb
15
Aug 14, 2009 12:07 AM
dankbred31
1978 - 1996 Big Bronco
Dec 23, 2008 11:35 AM
