Fenderwell Exit Headers
Old Jul 3, 2003 | 03:35 PM
Racerdave's Avatar
Racerdave
If he said he was going to use the tape I was going to say the same thing Tourque1st.
Old Jul 3, 2003 | 04:39 PM
77'F-150Mudder's Avatar
77'F-150Mudder
Lifted78, I'm not sure if L&L makes headers for 351/400M. You can check at www.landlproducts.com.
The headers are coated with what L&L calls "electroless nickelshield plating". As far as wraping the headers, no I wasn't going to. In fact the information that came with the headers specifically says not to wrap them or it will void the lifetime warranty.
I didn't have to lift the engine at all. They slide in from the wheelwells. I had to remove the shock towers and do some trimming on the inner fenders with an air nibbler but otherwise they were a breeze to install. I had to trim about 4-5" out of the passenger side and about 1" out of the drivers side.
One other issue I'm about to go out and tackle is the fuel line. The hard line that runs up on the engine perch is a little close to the headers for my comfort so I think I'm going to cut it off down in the frame channel and run it under the perch. You can just make out the fuel line in the second pic between the steering shaft and the primary tube for #5.
Old Jul 3, 2003 | 04:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
Sounds like you are doing everything right and THINKING
Old Jul 3, 2003 | 04:44 PM
77'F-150Mudder
Originally posted by Torque1st
Going over the outside of the frame gets them away from the starter also
Torque, you read my mind. Thats one of the two reasons I went with fenderwells. The other reason is because I really don't like the clutter between the frame rails that dual exhaust adds. Working on the trans/t-case is sooo much easier without exhaust in the way.
Old Jul 3, 2003 | 05:09 PM
rompin78's Avatar
rompin78
Hey 77'F-150Mudder, what did you do with brake lines that run between your proportioning valve and your master cylinder??? Thanks!
Rompin 78'
Old Jul 3, 2003 | 09:07 PM
77'F-150Mudder
I haven't got them routed yet. I'm still looking for ideas. I was hoping someone else with fenderwells would post what they have done and perhaps post a pic. I've read general descriptions here on FTE but nothing specific. It shouldn't be too hard. I'd just like to hear of other peoples experince before I do the 'ol trial and error method.
Old Jul 4, 2003 | 12:30 AM
tellico racing's Avatar
tellico racing
I am installing a set of fenderwell exit L and L's right now. I pulled my front clip off to put them in though, there really isnt that many bolts holding it on and it seemed easier than pulling all the rusted shock mount bolts.
I will post tomorrow on what I did with the various lines ect.
Old Jul 4, 2003 | 10:24 AM
rompin78's Avatar
rompin78
That would be great tellico racing!
I asked a guy at the local auto parts store and he said, he wouldn't recommend running the brake lines between 2 of the header pipes, which I have to agree, however he said you could bend the brake lines a little, but he mentioned he would do it with a line bender not by hand and route them up and out of the way. May end up doing that.
A buddy of mine mentioned seeing if they had any soft lines that would go between the valve and master cylinder, like the rubber lines that attach from the axle to the frame, I asked the guy at the auto store and said they didn't make anything like that, that he was aware of.
Rompin
Old Jul 4, 2003 | 10:41 AM
rompin78's Avatar
rompin78
Hey all got a little freebie digital camera last night so I snapped some pictures of what I have done. I have more but they are all from a regular camera, I will post them when I get them scanned in! Not bad for a freebie, hey, the price was right!
Rompin
Old Jul 4, 2003 | 02:23 PM
tellico racing
So far, I bent the brake lines back toward the firewall to miss the header, this can be done by hand....just don't kink them.
I also had to trim the bottom of the cab mount bracket on the drivers side to clear the tubes.
Well, break time is over ...... gotta go finish it up. I will post pics later of the different things I encountered.
Old Jul 4, 2003 | 04:18 PM
Torque1st's Avatar
Torque1st
Posting Legend
rompin- Flex lines will decrease your pedal firmness. Only use flex lines where you have to. If you must use flex lines go with the SS braided lines.
Old Jul 4, 2003 | 11:38 PM
tellico racing
The first problem was the header hitting the shock bracket, so I dented it for clearance. I hated doing that to a brand new $400 set of headers.
[IMG][/IMG]
Next was the power steering lines hitting,
I re-routed them, I have the old metal body power steering pump I am not sure if the plastic ones interfere or not.
I trimmed the bottom of the drivers side cab mount bracket,
And bent the brake lines back toward the firewall.
Thats about it. the job really wasnt that bad. I am glad I pulled the front clip off though...easier than bending over the fenders to work on it.
Hope these help.
Old Jul 5, 2003 | 11:27 AM
  #28
77'F-150Mudder
tellico, are those L&Ls on your 78'? I was surprised to hear you had interference issues with the cab mount and shock tower. Mine fit like a glove. I was impressed. I too had to monkey with the power steering. It was just the return line for me though. My hard line is contoured a little different than yours. I currently have the plastic resivoir. That pump is very noisy so I bought a new pump which has a metal resivoir. It shouldn't be any different though. I guess I'll find out later today when I get the truck back from the exhaust shop.
Did you just get your headers? If so I bet ours are from the same batch. Mine don't have the litte tag welded on the #5 primary though.
Old Jul 5, 2003 | 11:55 AM
  #29
rompin78's Avatar
rompin78
Geez tellico, sorry to see that you had so many little problems! Mine was only the bracket! Thanks for the pictures!! I think I may do just what you did and bend them up by hand. I wonder if I could still mount them to firewall of the cab in the same general area on the lines as would have been if I used the bracket. i will play around on it some and see what I come up with!
Thanks again!!
Rompin
  #30
tellico racing
They are L and L. I think the problem was the installation of the engine by the P.O. It looks a little crooked.....not too bad, I only had to trim 1/4 inch off the cab mount bracket.
Mine had a date on them of 11/02. I bought them off ebay from some guy in Canada.
