intake carb stud thread size
Old Mar 21, 2014 | 09:42 PM
70-360fe's Avatar
70-360fe
Anybody know the thread size for a carb stud on a 1970 f-100 390 fe engine? Thanks.
Old Mar 23, 2014 | 12:34 AM
orich's Avatar
orich
5/16"x18-threads this is for the carb base...
orich
Old Mar 23, 2014 | 04:35 AM
70-360fe's Avatar
70-360fe
[QUOTE=orich;14190050]5/16"x18-threads this is for the carb base...
orich[/QUO
Thanks! Now I can get longer ones without taking one out.
Old Mar 23, 2014 | 04:46 AM
User 71024's Avatar
User 71024
most carb base studs are coarse in the manifold but fine on the nut end. IF you care.
Old Mar 23, 2014 | 08:26 AM
70-360fe's Avatar
70-360fe
[QUOTE=EricJ;14190198]most carb base studs are coarse in the manifold but fine on the nut end. IF you care.[/QUOT
Yea that's what I thought so I did not want to get a stud according to the nut off present stud. My carb started to whistle, did some research and sounds like my base plate below the carb may be warped. Figured it would be a good time to replace the too short studs, the nuts barely go on. Thanks for the help.
Old Mar 23, 2014 | 09:18 AM
orich's Avatar
orich
[QUOTE=70-360fe;14190459]
Oh Yea that's what I thought so I did not want to get a stud according to the nut off present stud. My carb started to whistle, did some research and sounds like my base plate below the carb may be warped. Figured it would be a good time to replace the too short studs, the nuts barely go on. Thanks for the help.
Yeah, I've had the tall 2" black plastic type one leak due to the way it's made from having the hollow walls.
I was thinking about filling the wall pockets with a epoxy but then said the hell with it. Since, I already a aluminum one!!
orich
Old Mar 23, 2014 | 09:47 AM
User 71024's Avatar
User 71024
piece of coarse sand paper on a pane of glass makes a nice plane to flush up the warped or dinged riser plates, works on the aluminum and the plastic ones.
Old Mar 23, 2014 | 10:54 AM
orich's Avatar
orich
Yes but it don't stop the plastic one from warping the gasket in the hollow wall ones.
As this was what was happening in my case. This was why I thought about filling in the wall hollow walls. This if using the tall spacer with the hollow walls that is..:
orich
Old Mar 23, 2014 | 11:36 AM
70-360fe's Avatar
70-360fe
This is just the original heat riser, plate of glass is a good idea.
whisler
Nov 4, 2014 10:38 AM
85blue
Apr 15, 2011 10:05 AM
TheMachfather
Apr 4, 2004 10:05 AM
