Can’t find the OBDI Port on my 1997 Ford F350 5.8L E40D Transmission…
Old 03-21-2014, 06:27 PM
synvolk's Avatar
synvolk
synvolk is offline
Hi everyone,
I am kinda new to this forum and have been lerking for a while now, and really like the site...
I bought this truck form a local town government fleet. It has 101,000 and the transmission is hard shifting…
In my research I found that one of the 1st things to do as a diagnostic tool would be to check for codes…
Got under the dash and, if there is one under there, I cannot find a OBDI port to plug into…
Has anyone ever seen one of these without a port, or could it located somewhere else?
Also, does anyone know what this part is, and shouldn’t it have something hooked up to it?
Any input would be very helpful.
Thanks...
Old 03-21-2014, 07:50 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
OBD1 ports are under the hood, usually on the firewall near the PCM. OBD 2 ports are under the dash near the steering column as per regulation.
The last of the old generation Super Duty trucks were weird birds. It's probably an EEC-IV PCM and the connector is under the hood.
Old 03-21-2014, 07:57 PM
synvolk's Avatar
synvolk
synvolk is offline
Thanks... good info.. I'll check that out tomorrow...
Any ideas on the pics?
Old 03-21-2014, 08:09 PM
JWC 3's Avatar
JWC 3
JWC 3 is offline
I do think it is located around the driver hood hinge area .
Old 03-22-2014, 07:29 AM
projectSHO89
I can only guess that it's part of the secondary air injection system, part of the emissions control system.
Keep in mind that, if it's an EEC-IV processor, your modern scan tool will be useless.
Old 03-30-2014, 06:27 PM
synvolk's Avatar
synvolk
synvolk is offline
The engine in question says Ford 5.8 EFI
So.. was this one supposed to have the OBD2 under the dash, or not?
Also, what kind of reader do I need to pull some codes, as the OBD2 is nowhere to be found under the dash in the usual place..
Old 03-30-2014, 09:34 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,641 Likes on 1,102 Posts
OBDI ports were all under the hood. Ford never made the 5.8L OBDII compliant.
Barney58F100
05-09-2024 06:34 AM
hlozano
2017+ Super Duty
16
03-08-2021 09:31 PM
hurricane62
03-12-2020 07:18 PM
devoalan
03-14-2013 09:53 PM
jfmaz
10-12-2009 12:09 PM
Quick Reply: Can’t find the OBDI Port on my 1997 Ford F350 5.8L E40D Transmission…
