77 Highboy Price
Old Mar 20, 2014 | 07:46 PM
PhilMac's Avatar
PhilMac
77 Highboy Price
Hey guys, Ive got a '77 F-250 Highboy SCLB that I am interested in selling. Body and interior are in rough condition and needs a total restoration however it is a solid platform. Has D60 rear, D44 front, C6 and NP205 Tcase. It does not have a engine but had a 460 in it. This is a truck that my dad owned when I was a kid and my life long dream had been to fix it up like new, unfortunately I have realized it will take much more time and money than I have. I have rebuilt the 460 and have it sitting in the basement. My new goal is to buy a 92-96 Bronco to put it in, swap to a zf5 and install bigger axles. My hope is to be able to sell the 77 without the motor and get enough to at least start the bronco project. However at this point I do not know what it is worth. Can anyone give me some thoughts on what its worth?
Thanks
Old Mar 20, 2014 | 07:50 PM
PhilMac's Avatar
PhilMac
Also for what its worth, ive rebuilt the front hubs and installed new bearings, rotors, calipers, pads and rubber lines.
Old Mar 20, 2014 | 08:21 PM
bucks77ford's Avatar
bucks77ford
Edited post from answer below. I thought sclb was supercab long box.
Old Mar 20, 2014 | 08:40 PM
PhilMac's Avatar
PhilMac
sorry its actually a single cab. my sclb was misleading.
Old Mar 20, 2014 | 10:39 PM
twinzilla's Avatar
twinzilla
Where are you located?
Old Mar 20, 2014 | 10:49 PM
Jklnhyd's Avatar
Jklnhyd
Rough body, rough interior, no engine. This is a parts truck. I would just guess from no pictures, $300-$400? Maybe not even that
Old Mar 21, 2014 | 08:30 AM
Dave145's Avatar
Dave145
Are you talking about the truck you have posted as your profile pic? If so, $600 at best. Parts trucks don't go for very much... Especially if both the body AND the interior are shot. The fact that its got no engine doesn't help it at all either.
Old Mar 21, 2014 | 08:56 AM
PhilMac's Avatar
PhilMac
I am located in Birmingham, Al. Yea its the truck in the pic. If its not worth any more than that I will likely save the axles for the bronco, sell the trans and tcase and scrap the body and frame. Just kinda hated to scrap her. I would sell it with the engine but I think I would lose money with what i've got in the engine. Its built right and strong.
Old Mar 21, 2014 | 09:04 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Put it on the FTE classifides and the local Craigslist, the truck itself looks like maybe a 5 to 6 hundred parts truck, sorry.
Have all the eng build info and recirpts to back up that you are asking for the motor....
You should be able to ask what you can prove in reciepts for parts and machine shop labor/time.
Have you posted it in your local FTE state chapter?
Old Mar 21, 2014 | 09:06 AM
twinzilla's Avatar
twinzilla
If you weren't so far away I'd make you an offer.
Old Mar 21, 2014 | 09:12 AM
PhilMac's Avatar
PhilMac
I am fairly set on keeping the motor because I built it myself and even the engine is a little centimental beacue it was my dads truck. I haven't posted it yet but I will give it a shot. Just called my local scrap yard and they are giving .10 a pound so I am curious what the body and frame will weigh? Also, would that front d44 be a good swap for a bronco?
Old Mar 21, 2014 | 09:18 AM
77&79F250's Avatar
77&79F250
I guess 4500 ish lbs, without motor.
If a guy will swap you a running and driveable bronco for that D44 get on it, but it will make for a PITA time to move that truck around with out the front axle.
FYI a D44 is not like D60 $ wise.
Old Mar 21, 2014 | 09:27 AM
bucks77ford
I'd maybe just part I out. Yea, the axles should bring $150 to $200 each and that t case should be $200 or so if it's good. If the tranny is good, it should be $100. Otherwise your looking at $450 from the scrap yard.
Old Mar 21, 2014 | 09:35 AM
PhilMac's Avatar
PhilMac
77&79, you think i could swap the d44 for a bronco or am i misunderstanding?
Old Mar 21, 2014 | 09:41 AM
twinzilla's Avatar
twinzilla
Looks like he thinks you're trading it for a Bronco. Personally I wouldn't wast my time swapping it into a Bronco.
