A/C discharge check
Old Mar 20, 2014 | 04:18 PM
truckpastor's Avatar
truckpastor
A/C discharge check
About to dismantle my 84/part out. It's been sitting a while and my question is, when I push on both ac Schader valves nothing hisses. Am I safe to assume the ac has no pressure and I can not worry about disconnecting ac stuff? Thanks
Old Mar 20, 2014 | 10:35 PM
Gary Lewis's Avatar
Gary Lewis
If you don't have anything escaping when you press the valves down then your system is discharged and you can take it apart. However, just in case both valves are plugged I would wear safety glasses and gloves when you take the first connection loose.
Old Mar 20, 2014 | 11:27 PM
truckpastor
System had nothing, all ac stuff is off. Thanks
FordPickMeUp
May 25, 2022 02:32 PM
mtnmikev
Jul 29, 2017 08:51 AM
fordinmudd
May 26, 2010 09:05 PM
galaxie223
Jul 31, 2003 09:20 PM
