ect
Old Mar 20, 2014 | 02:34 PM
g tinsley's Avatar
g tinsley
ect
My 2005 6liter eot runs 190 but ect never gets above 186 is this okay I just got a scanguage and installed a coolant filter. The ect always reads a little less than the eot.
Old Mar 20, 2014 | 03:05 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
More or less that seems to be the expected temp range for a normal t-stat. Ideal is 190+ with the temp spread less than 15 @ 65 mph
Josh
Old Mar 20, 2014 | 03:37 PM
69cj's Avatar
69cj
You more than likely could use a new t-stat.
Old Mar 20, 2014 | 04:25 PM
Green96's Avatar
Green96
What are the air temperature where you are at? I have notice my truck will run at 184-188 in 40*F or less, but as the outside air temp heats up it will get to 190*F or slightly over. Like the others said, make sure you EOT is no more than 15*F above your ECT. That is the acceptable norm.
6.0ForLife
Apr 20, 2019 03:52 PM
cornstar6207
Aug 11, 2015 07:15 PM
glockholiday
Nov 30, 2014 07:20 PM
WH90
Sep 28, 2010 11:01 PM
