Sponsored by: Real Truck
Bed questions
Old Mar 20, 2014 | 12:26 PM
antl14's Avatar
antl14
Bed questions
I recently purchased a 2002 F250 Super Duty supercab. The only issue was that the bed has much rust. Being mechanically inclined, I decided that if the swap is easy enough and inexpensive I will do it. I assume that a lot of these beds rust in the Northeast because of all the moisture. I have also heard it is because of the foam insulation which holds moisture.
The bed I have is the 6.9'. Are any models after 2002 compatible? will a f-150 or f-350 from another year fit? Will there be any issues with the gas tank fittings? Any help will be appreciated, thank you.
Old Mar 20, 2014 | 12:39 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Don't know about the fit, but it's a major pain to get those bed bolts out. Start PB Blasting now haha.
Old Mar 20, 2014 | 12:52 PM
antl14's Avatar
antl14
Im sure I am just going to have to cut them off and buy new ones from Ford.
Old Mar 20, 2014 | 01:25 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Before you cut I advise you to look up those prices. You might think otherwise. However they are torque to yield which apparently to an engineer (which I am not) that means single use anyway. I don't know why you can't reuse them or normal bolts.
Old Mar 20, 2014 | 01:37 PM
xmontex4's Avatar
xmontex4
F150 beds may line up with the bolts however they have very different body lines and are usually shorter than the SD beds. Any 99-15 SD short bed will work though.
You can get bolts on ebay I payed $60 for 8 bolts and 8 clip nuts, they are from Canada and is from when they remove beds on trucks and install the utility beds.
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40 (the ones i got are on the very bottom)
From what I've learned as an engineering student (so far) and being an engineering intern for the past few years is that the yield is basically the breaking point. I'm assuming that once you tighten them any more they will break in some way or lose its structural integrity. Idk how it would affect unscrewing it but I'm assuming that's why the bits will break orthe heads will before they loosen up. I bet a real engineer will chime in but I haven't gotten that far into my classes yet just going based of what i hear at work lol...I'm really interested now I may go ask my boss why torqued to yield is "a one time use".
Old Mar 20, 2014 | 01:41 PM
Kdr358's Avatar
Kdr358
There not true "bolts" they are basically long screws that cut themselves and imbed themselves into the clips. That's why so many torx bits get broken.
Old Mar 20, 2014 | 02:01 PM
xmontex4's Avatar
xmontex4
True I forgot about that it makes thdm a pita to get out. I'm still I terested in the torque to yield topic ill find out from an engineer at work and let you guys know.
Old Mar 20, 2014 | 02:20 PM
thomabb's Avatar
thomabb
Torque to yield bolts are commonly used where fatigue failures are an issue. They physically stretch beyond the elastic phase when they are tightened, and therefore are permanently deformed. This process theoretically allows the bolt to hold down what it is tightened against with more force at the same torque. This keeps the two joined components from moving as much, thus reducing fatigue.
I didn't know the bed bolts were TTY. Interesting...
Old Mar 20, 2014 | 02:40 PM
antl14's Avatar
antl14
Just to fully understand. Any 6.9' bed from any Super Duty 99-14 (f250 and f350) will match up perfect? Is this also true about the gas grommet and so forth?
Old Mar 20, 2014 | 05:26 PM
xmontex4's Avatar
xmontex4
Yes, the 11+ beds have a different gas cap area because they started to offer CNG then so the filler tube still fits but needs to be muscled over a little. Also I want to note that the 11+ beds follow the same body line but uts more defined so it wont match the front fender but if you just want a bed and dont caere about looks then they are fine.
Old Mar 20, 2014 | 06:25 PM
Maxium4x4's Avatar
Maxium4x4
Short bed will be hard and expensive to find if you run into one $$$ Long beds are all over the place. 99 to 2010 are direct fit, as mentioned (2011+) the wheel opening is different but not a game killer. Fuel door is no big item either and nobody will notice it unless they are a die hard Ford Truck fan.
2011 and up requires a little wiring on the tail light, the reverse light is at the top, not bottom.
Old Mar 20, 2014 | 06:29 PM
xmontex4's Avatar
xmontex4
You can reuse your old tail lights if you wish though. Is the socket any different for the 08+ lights or just higher up in the housings?
Old Mar 20, 2014 | 06:34 PM
Maxium4x4's Avatar
Maxium4x4
I never physically got that far because I found new take-off 2010, guessing the sockets are the same, you drag over your old wire harness.
Old Mar 20, 2014 | 08:45 PM
1977cutcher's Avatar
1977cutcher
Torch the bolts off, and buy new. Only way to go, I tried to save them and it was a waste of time. If you need new rear shocks, or have any concerns about the fuel pump the time to change them is when the bed is off. Also a good time to check break lines, ect.
Borgia
Aug 16, 2017 02:52 PM
kdv
Oct 21, 2015 03:06 PM
big94red
Jul 20, 2012 05:52 PM
kian
Dec 20, 2008 04:13 PM
Longneck
Jan 28, 2003 08:04 PM
