. If it's giving problems, may not want the exact same one...
. A machine shop can measure lobe lift easily and tell you about what it is... if there's no identifying marks on the end of it...
. Wouldn't go bigger than stock cam spec's in a stock engine because of the way low stock compression ratios/already poor MPG in these engines... SummitRacing.com has low priced cam/lifter kits in most popular sizes...
