Crane Cam question
Old Jan 3, 2018 | 11:44 PM
AZTrooper's Avatar
AZTrooper
Crane Cam question
I am looking for a stock 1971 302 profile, but cannot find. If they do not have the exact profile, of which I have conflicting data for what that truly is, then I was looking at H-260-2. I am going for stock on this build. If anyone has either the true Ford 1971 cam profile, please share (I looked and found conflicting data on posts). And if anyone knows the Crane cam which fits it, or possibly another mfg for the stock profile. On that note, I am only looking for US made cam companies. I have always been partial to Crane, with Isky also being in there. Thank you in advance.
Old Jan 4, 2018 | 10:13 AM
Filthy Beast's Avatar
Filthy Beast
Here's a couple:
Stock replacement cams: FMC #C3AZ-6250-V.....Howards Cams, #217311-09
Melling #SYB-25
Stock 289/302 cam specs:
Duration - 184/189 @ 0.5"....Ford's idea of duration was just as the lifter started up the ramp, so take that into consideration..
Lobe lift - 0.230/0.238
Gross lift (@ valve) - 0.368/0.380
Centerline - 114/104
Intake Opens/Close -16*-20* BTDC / 70* ABDCExhaust Opens/Close - 44* BBDC / 20*-24* ATDC
LSA
- 109
Rocker ratio - 1.6
Old Jan 4, 2018 | 09:20 PM
AZTrooper's Avatar
AZTrooper
Thank you for the info, Filthy. Went with Howards Cam. Real nice folks when I called them.
Old Jan 5, 2018 | 06:46 AM
Filthy Beast
You're welcome.
I'm sure there are others...Comp Cams, Lunati, Summit brand, etc, that you could cross reference...even Crane. Your call.
1979f-100
May 20, 2009 08:16 PM
Jason8705
Aug 5, 2007 02:00 AM
gunnabebad
Feb 28, 2004 04:19 PM
jwtaylor
Dec 5, 2003 10:02 AM
EXOPAR
Jan 17, 2003 11:58 AM
