Coolant Flush Frequency
Old Mar 19, 2014 | 11:48 AM
Nardo1895's Avatar
Nardo1895
My truck is a 2004 6.0 diesel with about 50,000 miles. It use to be my daily driver but is now mostly my tow and haul vehicle. Two summers ago I had a blown head gasket. The Ford dealer told me that while the coolant would last 100,000 miles, sediment builds up a lot faster than that, which is what led to the head gasket failure. I read the Tech forum about how to do a flush -- great information. My question is, how frequently? The dealer told me to do it every 18-24 months. I probably drive about 2000 miles in that time period, most of it under some kind of load. I suspect that with how little I drive it, its more of a time issue than mileage. I'd rather not have to deal with another $5K repair, but that flush frequency seems a bit excessive. Thoughts?
Old Mar 19, 2014 | 12:05 PM
VQT's Avatar
VQT
You should at least buy a scanguage II to monitor the coolant temp and oil temp., the SG II also provide other important informations for the engine performance.
Did you just replace the head gasket two years ago or the oil cooler and egr cooler were also replaced? From what I understand, blown head gasket wasn't just because dirty coolant. It is from clogged oil cooler due to particles from coolant which in turn crack the egr cooler, then the head gaskets. To prevent this, you need to check the condition of the oil cooler via temp difference between oil and engine.
Get a coolant filter to clean out the supense particles in the coolant.
There is a test for the coolant ph if you want to monitor it before the need to change every 24 months.
Other with more experience and knowledge will provide better explaination and guidance later...
Old Mar 19, 2014 | 12:32 PM
Nardo1895's Avatar
Nardo1895
You are correct, oil cooler and egr cooler first, then the head gasket(s). All were replaced.
Old Mar 19, 2014 | 01:31 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Ford Gold I would do 30,000 miles, ELC 100,000 miles to be on the safe side though it's good for 500K+
Josh
Old Mar 19, 2014 | 05:16 PM
Rusty Axlerod's Avatar
Rusty Axlerod
I like the 24month schedule. I plan on doing that with silicate free ELC, but honestly, ignoring it until it turns to mud is the real problem. These newer coolants are capable of going several years and still be serviceable.
Old Mar 19, 2014 | 06:34 PM
nico963's Avatar
nico963
I do every 30,000 with the Ford Gold going back in like Josh said.
Old Mar 19, 2014 | 06:58 PM
Rusty Axlerod
Not trying to be picky, but coolant can go bad in a vehicle that's never driven. Heat cycles will reduce coolants lifespan and mileage can work for you if you drive regularly, but really I think it's a time issue more than miles.
Old Mar 19, 2014 | 07:04 PM
nico963's Avatar
nico963
I have often wondered about time vs miles.My truck sits alot in the winter.
Old Mar 19, 2014 | 08:14 PM
Sullid01's Avatar
Sullid01
I am doing 36mo changes. With a coolant filter and good temps, I think this is more than reasonable. Hard to argue with sooner, but it is likely unnecessary.
Bluepowerstrokin
Feb 27, 2017 08:25 AM
LO 6.0
Aug 24, 2013 12:13 AM
PRDATOR
Nov 30, 2011 06:41 AM
HeavyTow
Nov 28, 2010 04:07 PM
SqueeK
Sep 10, 2009 01:20 PM
