Sponsored by: Auxito
lock cylinder?
Old Mar 16, 2014 | 12:34 PM
big job's Avatar
big job
lock cylinder?
Ok I have replaced several Ign / key/ lock cylinders. This one 97 350
wont turn move "its done" any ideas other than a bigger BF hamer?
four foot pipe wrench to move it so I can do the punch 'pin release thing'?
or smash it.
Old Mar 16, 2014 | 04:07 PM
projectSHO89's Avatar
projectSHO89
If it won't turn with the key to get into the position to remove it, you will have to drill out the cylinder. See workshop manual.
If you force it, either with a BFH or a pipe wrench, you will end up breaking the casting around the cylinder and you'll have to replace the column.
Old Mar 17, 2014 | 03:24 AM
big job's Avatar
big job
thanks thats what I thought.
Old Mar 17, 2014 | 06:21 AM
Spotty's Avatar
Spotty
Did you try another key? Could it be the ignition switch itself is stuck not allowing the cylinder to turn? Maybe take the screws out and drop it out and see if the cylinder and rod will move??
Old Mar 17, 2014 | 06:59 AM
2Fords1Jeep's Avatar
2Fords1Jeep
Try using Tri-Flow lubricant in the cylinder to unbind the wafers.
Old Mar 17, 2014 | 12:50 PM
big job's Avatar
big job
All I can say is the truck came in ok the next day cant turn it for the life of
me. As said we have replaced many with out drilling. So It will be awhile
to cold for an extention 110 for an electric heater. Next plan is I will need
Ign switch elect diagram then put a, say 1979 ign switch on the dash and
get rid of all this new day crap....someone said drill it ok what size drill??
just want to get the guts out I dont know the id of the tumbler....
the best system was 1932 thu 1946 coincidal locks fail safe easy.
my old man always said "locks are for prisons"
Old Mar 17, 2014 | 01:15 PM
Spotty's Avatar
Spotty
Did you try wiggling the steering wheel back and forth while trying to turn the lock? I have never drilled one. I assume you would just drill the pin out thru the access hole. The pin is about a 1/4" deep and is a 1/4" in diameter at the very base that goes into the cylinder. The top of the pin that you push that goes thru the steering column is an 1/8th". That is also the size of the hole in the steering column ...(1/8th'') If it was me I would use an 1/8th inch bit and drill as straight as possible for a depth of 1/4". Then use something on the ears to "gently" snap what is left. I have done other ones before like this, but never this one in particular. I guess just go slow and don't go too big on the bit and ruin the steering column. This is just my own take on it...maybe it is the wrong approach, but all my knowledge seems to have come from breaking something first...LOL. Or skip all that and drive a Cats Paw in and listen to stuff shatter when you turn it.....
Old Mar 18, 2014 | 04:59 AM
big job's Avatar
big job
Yes Spotty, first I have to determine if it is in fact the key, maybe the
switch or I think theres a rack in there. But then, there is no give (trying
to turn the key) just like leprecons welded it overnight. and tried spare
keys too. suppose I will pick it up with the loader and put in the shop
where theres heat.
sam
Old Mar 19, 2014 | 04:40 AM
big job's Avatar
big job
All set; my son drilled it $61 from Napa. 15min job
Old Mar 19, 2014 | 06:44 AM
Spotty's Avatar
Spotty
Good deal.
BS51993
15
Dec 26, 2018 08:31 AM
ginoholt
Feb 12, 2014 10:35 AM
ginoholt
Jan 1, 2014 11:04 PM
trap4x4
Sep 16, 2010 09:49 PM
rluckey1
Dec 18, 2007 12:31 PM
