1978 - 1996 Big Bronco
1995 tailgate remote mechanism
Old May 3, 2014 | 01:38 AM
droppednutz's Avatar
droppednutz
At the motor I get 0.00 ohms and with a battery hooked directly to it the motor does work in both directions all the way up and down
Old May 3, 2014 | 01:42 AM
GruesomeJeans's Avatar
GruesomeJeans
So the wires you just spliced into the motor, those have 12v to them. And do you know for sure those are going to the switch up front?
droppednutz
Also at the red/yellow and yellow/red I get 0.00ohms when the dash switch is in neutral and infinite when the switch is pushed up or down.
Old May 3, 2014 | 01:45 AM
droppednutz
Those come from the key switch but its the same way with jumpering from the violet wires coming from the dash switch.
Old May 3, 2014 | 03:44 AM
GruesomeJeans
Hmm, that is all strange. So the PO bypassed the safety switch, are you bypassing the key switch? Those go bad often.
Old May 3, 2014 | 05:37 AM
droppednutz
I think that will be my only option but I'm not sure how.would it just be the violet wires frome the dash switch I'd use or would the ground behind the tail light NEED to get used?
Precisionair
Jul 21, 2018 11:14 PM
leejk
Oct 6, 2017 05:03 PM
Tim Hodgson
Jun 10, 2013 04:34 PM
chrisjrosenbohm
May 22, 2009 09:40 PM
sanscritt1
Oct 11, 2004 08:35 AM
