Ordered Edge Insight CTS
Old Mar 21, 2014 | 10:35 AM
BBslider001's Avatar
BBslider001
It didn't come with the long cable? Mine came with a 6' monster cable...way more than I needed! Glad you like it. I think you'll find it useful and easy to operate.
Old Mar 21, 2014 | 12:54 PM
1994F2507.3L's Avatar
1994F2507.3L
No the Cable I got isn't near long enough to run under the dash and back up the side to the a pillar I was hoping it would be longer
Old Mar 21, 2014 | 08:07 PM
rodneywar's Avatar
rodneywar
same here!
Old Mar 22, 2014 | 06:46 AM
1994F2507.3L
the cable i got was probably about 4 foot long or so
it did not run very well on my buddies mustang, if i played with the PID's to much it would go nuts and not read correctly, and it wouldn't display anything on my focus, it would get so far as to load gauges and then shut off, im hoping it works better on my truck
Old Mar 22, 2014 | 07:53 AM
scfdr13's Avatar
scfdr13
The edge is great for stock applications. If you modify the truck IE: injectors and such canned tunes are not the best for you. In that case save couple hundred dollars and buy the CS. No tunes just monitoring. I speaking from experience. New transmission wasn't cheap and I know it was the edge that did it!
Old Mar 22, 2014 | 08:01 AM
scfdr13's Avatar
scfdr13
I run the edge on the stock setting and pruchased a TS chip. 30 minute install.
www.wespeakdiesel.com/ $225. t6 6 POSITION CHIP WITH PRELOADED TUNES
STOCK,HIGH IDLE, 50HP, 75HP, 100HP, 140+HP
Can't beat the price
Old Mar 22, 2014 | 08:41 AM
1994F2507.3L
the Insight CTS is just a monitor, like the CS but full touch screen, i run a TS 6 POS for tuning. Same with BBslider
Old Mar 22, 2014 | 09:10 AM
scfdr13's Avatar
scfdr13
There's the insight and the evolution. I was speaking of the evolution.
Old Mar 26, 2014 | 06:22 AM
1994F2507.3L
Insight and EAS system wired in and ready to rock, I'm estimating truck competition at 2 weeks out.
Can these trucks not do the cylinder balance test Bbslider?
Old Mar 26, 2014 | 08:45 AM
BBslider001
Originally Posted by 1994F2507.3L
Insight and EAS system wired in and ready to rock, I'm estimating truck competition at 2 weeks out. Can these trucks not do the cylinder balance test Bbslider?
I am pretty sure it can't unfortunately
Old Mar 26, 2014 | 08:54 AM
pwjackson42's Avatar
pwjackson42
I think I will be getting one of these for monitoring also instead of spending as much if not more money on a 3 pillar gauge cluster.
Question, do you have to order an EGT probe with the Insight or does it come with one and also to add engine water temp do you need to order a special probe from edge?
Old Mar 26, 2014 | 10:34 AM
BBslider001
Originally Posted by pwjackson42
I think I will be getting one of these for monitoring also instead of spending as much if not more money on a 3 pillar gauge cluster. Question, do you have to order an EGT probe with the Insight or does it come with one and also to add engine water temp do you need to order a special probe from edge?
Probe is separate. Not sure about the engine water temp, but it does monitor engine oil temp. Engine water temp isn't as critical as EGT and EOT. If those are good, H2O temp will be good. The temp gauges in these trucks are pretty dependable.
Old Mar 26, 2014 | 11:33 AM
  #28
1994F2507.3L
You can order the EAS starter kit w egt probe for like 115$ that's what I did. To get engine water temp you need another system that attaches to the EAS starter kit w egt probe.
I bought all my stuff through Amazon.
Old Mar 26, 2014 | 11:59 AM
  #29
pwjackson42
Okay thanks guys! This to me looks to be money well spent then on standard gauges.
Old Mar 26, 2014 | 01:36 PM
  #30
1994F2507.3L
You do get quite a but more with the insight look it up on edges website and they'll show what all ya can see with it.
