Need some help!
Old Mar 15, 2014 | 07:15 PM
Daveyj's Avatar
Daveyj
Need some help!
What are the symptoms of the front axl u joints going out? While driving at slow speeds and turning it feels like my tires are rubbing on the fender. Doesn't matter which way I turn the wheel. It just has a vibrating feeling. I noticed it a while back while going in reverse. Sometimes it would have that feeling and other times it wouldn't. I'm thinking U joints or possibly the auto locking hubs? Any information you fellas can give would be great. I guess I shouldn't rule out bearings either
1997 f350 CCLB 4x4
Old Mar 15, 2014 | 07:35 PM
JCart's Avatar
JCart
Could be what you're describing another symptom is after rounding a corner steering wheel will not center on its own, you have to steer it back to center. Lock hubs, jack front end in the air and spin tires and listen look at joints try to see if they are loose.
Old Mar 15, 2014 | 09:01 PM
Daveyj's Avatar
Daveyj
Come to think of it, there have been a few times that the wheel didn't exactly want to come back to zero. I have had the front end up a couple months ago and did move the wheels back and forth while looking at the u joints. I didn't see any movement at all, but I hadn't engaged the 4 wheel drive.
Old Mar 15, 2014 | 09:02 PM
ProjectDually's Avatar
ProjectDually
Could be steering rack too possibly? I replaced mine a while back, along with the PS hydraulic line.
If what you hear is a rubbing sound, and sound like it's the tires, check the tires for abnormal wear on the tire.
IF there is wear, here's a good website I have used a couple of times.
Discover the types of wear on your tires - Kaltire
Old Mar 16, 2014 | 07:35 AM
tjc transport's Avatar
tjc transport
i ain't rite
it could also be a wheel bearing.
handymanhobbs
Dec 3, 2015 10:55 AM
Brian92390
Oct 20, 2014 04:29 PM
nkm
General Diesel Discussion
Jun 2, 2011 12:13 PM
4drf350
Sep 26, 2006 05:08 PM
deans316
Oct 27, 2005 02:05 PM
