Fuel Filter help
Old Mar 15, 2014 | 12:00 PM
Son's79f-150's Avatar
Son's79f-150
Fuel Filter help
Looking for suggestions on what kind of fuel filter to buy for my son's truck. It is a 79 F150 with a 351m. We just rebuilt the aftermarket 4 Barrel Carter Carb and added an electric choke. What is on it now is definitely not stock, it is an inline fuel filter. Do i need high flow or low flow. I don't want to restrict the fuel to the carb.
Old Mar 15, 2014 | 12:20 PM
fmc400's Avatar
fmc400
MSEE
A 351M shouldn't have a Carter carb unless you mean it has an aftermarket 4-barrel intake with an early (pre-Edelbrock) Carter. Nonetheless, just get whatever is specified in the book at the parts store. If you have the stock Motorcraft 2-barrel, it's a threaded filter. For standard brands like Wix and Purolator, they're not even going to ask about flow rate. Pretty simple job.
Old Mar 15, 2014 | 12:30 PM
Son's79f-150
Thanks for the info. It is an aftermarket Carb.
Old Mar 15, 2014 | 07:33 PM
Blue and White's Avatar
Blue and White
A standard in line filter in the same size as the carb supply line should work fine. Not too much restriction. I prefer the metal case type but any standard filter should work.
One thing to consider is fuel pressure. An OE pump will put out 7-9 psi. Sometimes that is too much for a Carter and will flood it. If the carb and fuel pump have worked well as a pair before there should be no problem. If not, you may need a fuel pressure regulator. Holly is best (Summit ect.). I believe Carters like around 5 psi.
crestfallinman
Sep 22, 2019 04:00 PM
kadrocker
Dec 17, 2009 09:01 PM
BIG-COUNTRY
Dec 30, 2005 05:41 PM
OzarksFord
Nov 16, 2005 01:39 PM
cigarxtc
Apr 11, 2003 11:38 AM
