Fuel filter
Old Nov 11, 2005 | 02:21 AM
OzarksFord's Avatar
OzarksFord
Question Fuel filter
My Haynes manual does show a fuel filter for my 1983 Ford F-150 (300 I6). Does this vehicle have a fuel filter and if so, where is it located? Thanks in advance!
Old Nov 11, 2005 | 02:26 AM
ford390gashog's Avatar
ford390gashog
it can be inline or screwed into the base of the carb.
Old Nov 11, 2005 | 10:49 AM
nc150's Avatar
nc150
On my 86 it was screwed into the base of the carb - real easy to change out.
Old Nov 13, 2005 | 05:01 AM
rfxj3's Avatar
rfxj3
I have both types - one is is inline between the fuel pump and the carb inlet and the other is a fitting that screws into the carb inlet. The inline filter is one that can be just dissambled and cleaned. The one attached to the carb should be replaced every so often (maybe every 36K or 3 years?)
Old Nov 16, 2005 | 01:39 PM
OzarksFord's Avatar
OzarksFord
I had to take the fuel line off from the fuel pump to the carb because it crossed over the valve cover and I was replacing the gasket. So that's what that thing is the fuel line screwed into. Never would have figured it was the filter. Never seen one screwed into the base of the carb. Thanks! OzarksFord
