severe miss under load
Old Dec 9, 2012 | 01:31 AM
customk2500's Avatar
customk2500
ok i did a swap in my 96 f250 from a 460/at. to a 4.9l/ 5 speed now i have a severe miss under load i used the whole wiring harness/sensors/comp. from a running driving 95 f150. so this is my issue if i time it to 10* btdc(with the spout pulled) and put the spout back in it advances the timing like it should until you put a load on it then it retards the timing back to base and misses to the point of not being able to drive it. also if i open rev it it will miss at full throttle but if i reduce it to half throttle it climbs to 5k just fine. it misses worst at 2500-3500 rpm. its stumped everybody i've asked including a freind of mine that was head ford tech for 30 yrs at the local dealer. any help would be appreciated thanks. nate
Old Dec 9, 2012 | 03:06 AM
bdelmar2's Avatar
bdelmar2
Have a look at your spark plugs.
A bad wire or bad plugs can cause misfires under load.
Possibly rotor, cap or coil, but less likely.
How is the fuel pressure when it does this? Low fuel pressure/volume can cause a miss under load as well.
There is a fair chance that the misfiring is triggering the knock sensor and the computer is retarding the timing. Making it a symptom rather than a cause.
But you could try unplugging the spout to see if it makes a difference.
Old Dec 9, 2012 | 10:15 AM
42x's Avatar
42x
Replace your sparkplug wires. Check to see if there is a ground around the exhaust manifold/headers and keep the wires seperated. I installed heat resistant insulators around the spark plugs to ensure there was no grounding.
Old Dec 9, 2012 | 01:33 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
I try to have road-side swap-able spares in the truck for some of the common parts that fail. They can also be good diagnostic tools. The fact that you're loosing ignition advance, two things come to mind... TFI and PIP. TFI is easy to replace, especially since it's remote on the '92 - '96 trucks. I'd try that first, if only because it's so easy to swap.
Most just swap in another distributor rather than replace just the PIP. This is because the gear needs to be pressed off the shaft to swap the PIP.
Certainly all the other ignition components are suspect, as others have suggested.
Old Dec 9, 2012 | 01:46 PM
pfogle's Avatar
pfogle
Did you replace the fuel pumps? They are different between the V8 and I6 trucks.
Old Dec 9, 2012 | 11:48 PM
customk2500
i recently rebuilt the motor so plugs/wires/cap and rotor are all new. and before anybody says it i DID time the cam to the crank correctly i had this same problem before i rebuilt it. now before i forgot to mention that if i manually advance the timing to more than 30* and leave the spout out it runs as it should. as far as the fuel pumps those are the same betwenn the two its the fuel pressure regulator thats different. all ignition parts are good i installed them on my brothers 95 f150 and it ran perfect
Old Dec 10, 2012 | 11:39 AM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Try another PCM. These things are increasingly failing due to capacitor leakage and the symptoms are all over the map. I won't travel without a spare so it's a good investment even if it turns out not to be the source of your problem.
Old Dec 10, 2012 | 12:36 PM
customk2500
pcm is good. i'm gonna order a new harmonic balancer i was just told its a common problem that they spin on the hub.
Old Dec 10, 2012 | 01:00 PM
DPDISXR4Ti's Avatar
DPDISXR4Ti
Ah, I did read once before about someone else having that problem. But I was under the impression that it typically moved some fixed amount and stayed there rather than repeatedly rotating back and fourth as the crank accelerated.
Please report back if that solves it. In the mean time, I'll throw my extra in the bag for long trip travel spares.
Old Dec 12, 2012 | 11:05 AM
customk2500
well i got the harmonic yesterday, pulled it all apart and compared the timing marks my old one is off by 10* compared to the chinese one i got so thats not the issue. BTW dont by a dorman harmonic balancer unless you buy a speedi sleeve with it the one i got came with a very rough seal surface
jmthunderbirdturbo
1978 - 1996 Big Bronco
31
Aug 24, 2015 01:12 PM
sloburban
22
Oct 25, 2014 06:50 AM
drjoe171
Dec 3, 2010 07:46 AM
tankhokie
Jul 8, 2004 10:44 PM
kameronth
Jun 7, 2004 09:05 AM
