My E350 starting doing this thing when it kicks into OD. Between 40-55 mph the engine shutters. If I gas it, or let off, no problem. I checked and cleaned connects to the trans. I really think this is a spark or maybe fuel delivery issue. Of course, not a single code being thrown. Anyone seen this???
Does it sound like you're running on the rumble strips cut into pavement ? If it does, a bottle of Lucas Transmission Treatment will fix it. It's the solenoid inside the transmission that controls the OD function sticking. The Lucas treatment will free up the solenoid.
That's completely wrong. You don't even know what transmission he has. Most of the transmissions in the vans do not have a solenoid that controls the OD function.
Mine does. It's an E4OD. My 95 E150 had the same transmission an developed the same shudder at 150K miles, The bottle of Lucas fixed it within a couple blocks of adding it. You're wrong here, not I
No, I'm not. The E4OD DOES NOT have a solenoid that just controls the overdrive function. Only the 5R110 TorqShift does.
Do you really want to argue transmission function with me? That would be fun!
It's got a button on the end of the shifter that engages and disengages the OD function, whether or not the switch inside the transmission is a solenoid or not is irrelevant. The fact remains that once it develops the shudder a bottle of Lucas will fix it. The part inside the transmission that causes the clutch in the torque converter to engage gets gummed up over time, thus causing the part that makes the engagement happen, to flutter and cause the shudder. Now if you want to continue to deny that this phenomenon happens go right ahead. I KNOW what I'm talking about here because it DOES happen. You won't be the first "engineer" to be proven wrong about something.
I have the same issue when the converter locks up.
engine is smooth as anything except when the converter locks up at 45 or so. If i step on the brake, the "solenoid" releases and it is fine again.
My tranny also has a very abrupt drop into and out of converter lockup mode.
As said earlier, tranny is great otherwise.
Mark, if the 4r70 doesn't have a solenoid, what initiates converter lock up?
A solenoid initiates converter lockup. He was talking about overdrive. He doesn't even know the difference between converter lockup and overdrive, and he's trying to lecture me about how a transmission functions. He doesn't have a clue.
The shudder problem is NOT due to a gummed up solenoid. Once again, he's totally clueless.
There has been torque converter shudder issues with the 4R70W. It DOES NOT happen from a gummed up solenoid. He is just making that up because he doesn't know anything about the internals of a transmission.
The cause of torque converter shudder is a change in the frictional characteristics of the ATF. As the fluid ages it changes and it affects how the PID controller in the PCM controls the converter clutch. New fluid fixes this, and probably Lucas fix it, too. If the converter is allowed to shudder long enough it will damage the converter and it will need to be replaced.
Dude you're in a stream squirting contest but sadly too inadequately equipped to even dream of winning. IOW you've brought a spoon to a knife fight---chances of surviving a bit slim needless to say!
Does the abrupt drop into lockup mode also happen because of atf fluid issues also?
It is almost as if my van can wait to get into lockup mode in 3rd and 4th gears.
And when it is in lockup mode during steady state cruise conditions, i get a pretty harsh release when I step on the gas to accelerate. Almost as if it is fighting the release. If I tap the brake before I hit the gas, it is a much gentler release.
Isn't it amazing how some people think that they know everything?
I may be clueless as to how the internals of these transmissions work, but the fact remains that adding a bottle of Lucas Transmission treatment to the fluid WILL fix the problem (for the time being) Forgive me for actually trying to help the OP with his problem. At least I came up with a solution that WORKS. You're the engineer here, why don't you come up with a cure that fixes this problem instead of puffing up your chest in a vain attempt to show everyone how superior you are above others ?
I don't see you adding anything constructive to the problem. So maybe you should butt out before getting your feelings hurt.
What I suggested as to the cause of the problem is my theory. I DO know I had the problem with my 95 with it's E4OD and adding the Lucas fixed it for several thousand miles afterwards, it did pop up again the day I sold it, we added another half bottle to it then and it ended that episode too. Part of my theory was based on what's printed on the Lucas bottle about it freeing up sticky parts in an auto transmission. I had a 68 Merc Monterey a few years ago as well and it's C6's operation was also affected by sticking parts (it had never been rebuilt as it only had 60,000 miles since new) Once again the Lucas fixed that issue too (hard shifts from sticking parts) All that aside, all you'll be out is the cost if the Lucas, it's far better than the cost of a rebuild at this point. I was quoted $1500 to rebuild my E4OD back when I had my problem and that was nearly 10 years ago.
