Sponsored by: Innova
2005 E450 stereo
Old Mar 14, 2014 | 06:31 AM
bipix's Avatar
bipix
2005 E450 stereo
Im trying to install an aftermarket stereo. The factory stereo wire harness has the speaker wires connected via a 9-pin clip, and the power/ground etc. was hardwired in. Im trying to connect a dual xdma6630 and am not quite sure where to start.
My brother in law disconnected the speaker wire clip, and cut the hardwired cables. I looked up the wire color code, and noted that there is a black wire, and 2 black/green stripe wires. the code says that the ground wire is black/green stripe. Thus I am thoroughly confused.
Any ideas?
Old Mar 14, 2014 | 06:43 AM
JWA's Avatar
JWA
A bit late after all this has been done but Crutchfield and other car audio sellers have adapters for connecting aftermarket audio gear into stock chassis wiring harnesses without any cutting or splicing of the original chassis wiring harness required.
Follow your schematic to see where these questionable wires lead---that should get you back on track.
Old Mar 14, 2014 | 06:55 AM
bipix's Avatar
bipix
do you mean that there is an adapter that goes from the old stereo plug in to the harness that fits my aftermarket stereo? if that's the case, i can always go splice it back in. there were only 7 wires that were cut. the battery, 12v+, random black wire, 2 black/green ground wires, ignition and illumination wires.
Old Mar 18, 2014 | 08:05 PM
moosey78's Avatar
moosey78
Use the smaller gauge black and green wire As your ground.
Old Mar 19, 2014 | 07:41 AM
JWA's Avatar
JWA
Correct: http://www.crutchfield.com/g_103000/...s.html?tp=2977
I've used these several times and they're great for this purpose.
Old Mar 19, 2014 | 09:45 AM
moosey78's Avatar
moosey78
Junkyards are also good and most the time free
Old Mar 20, 2014 | 06:29 AM
JWA's Avatar
JWA
My time is worth more than that though!
If I can shop, point, click, buy and wait for it to show up on my doorstep that's the ultimate for me!
Old Mar 20, 2014 | 11:40 PM
bipix's Avatar
bipix
my guy is slightly too impatient to wait for a harness to come in the mail, so we went to a pick and pull and got another factory harness. we installed it, but still was not getting any power to the deck. my brother in law installed a direct power line to the battery, and everything works splendidly.
forager
Oct 16, 2018 12:15 PM
Christopher Workman
Feb 11, 2018 07:17 AM
Garry Chapman
Dec 29, 2013 08:58 AM
johnrebbb
Dec 20, 2003 03:38 PM
Walking_Tall_0403
Aerostar
Oct 27, 2003 01:05 AM
