On Going Starting Issue....
Old Mar 18, 2014 | 09:05 AM
HKusp's Avatar
HKusp
I am not saying this is the problem, because some of what you have going on is the opposite of what was going on when it was my problem- BUT... in the first video you posted, my truck did that exact same thing when I had a no start issue because of injector O-rings. I had just replaced the IPR and the ICP sensor because I had ICP too low codes and then it did that. All this happened a month after I had my 160/30's put in. I know you said you had good ICP (2000psi when cranking) but I just thought I would share. When did you put the 238/100's in?
kt19
21
Jan 9, 2014 11:17 AM
Dpotts94
Sep 17, 2012 06:32 PM
jkidd_39
Oct 4, 2009 01:38 PM
AndysFords
Aug 22, 2009 09:52 PM
Fourwheelinj1
Oct 22, 2007 09:51 PM
