2000 F450 PSD. HPOP blew the back out of itself. Have a HPOP from early 99. How can I get this pump to work to get truck home and properly repaired? Would simply changing the FPR to the 2000 modle work?
Thanks ... Ken Gardner
the e99 are 15* and L99 up are 17* pumps. either one will work the e99 pump will not put out the hp the later 17 will. put it on and run it to get home. the ipr are the same.
